Question about Garden
Series c950-521520 craftsman snowblower wont go into gear. The sprocket on the shaft does not grab by the washer clutch. The sprocket spins on shaft and wobles.
  • 66 Answers
SOURCE: kenmore 80 series washer not spinning
you need the gear box not the timer.
Posted on Dec 21, 2007
reddevil6
  • 1673 Answers
SOURCE: Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Posted on Jan 22, 2008
  • 59 Answers
SOURCE: kenmore washer will not spin or agitate, it makes noise
IN BETWEEN THE MOTOR AND TRANSMISSION THERE IS A MOTOR COUPLING PART # 285753A REPLACE THAT WILL FIX YOUR PROBLEM
Posted on Apr 29, 2009
wd4ity
  • 4565 Answers
SOURCE: starter drive gear wont engage on a HD fxrs
Sounds to me like the "overrunning clutch" is bad. You'll have to remove the starter and disassemble it. The starter drive is part #31663-90 according to the latest V-Twin book I have. It may have a different number on your 2000 model.
Posted on Sep 24, 2009
wireguy212
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
I have 2014 yamaha r1 an when i put into gear it will not go but i hear it click into gear what could be the issue?
The could be many problems first and easier would be the chain came off the front sprocket. Could be that the front sprocket came off of the shafts and the shafts is just free spinning or could be that one of your clutch plates aren't catching all the way.
Oct 27, 2014 | Motorcycles
Runs but wont go into gear. Just grinds after feeling a thump.
if the bike only grabs gears with the rpm way up there is a chance the clutch is gone or just about. make sure the clutch is properly adjusted. Also if it is a wet clutch be sure you have the proper amount of the right oil. if there is super old oil in the clutch plates they wont grab.
Apr 10, 2014 | 2002 Yamaha Xvs650 Xvs 650 Xvs650a V Star...
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Stairmaster left pedal clanks
The "clunking" you are describing is more than likely caused by either a faulty left drive sprocket, the drive shaft or a combination of both. The drive sprockets are equipped with a needle bearing type clutch. When they fail, the clutch does not grab the shaft and drive it correctly. You may just need to replace the left drive sprocket. In some cases you will need to replace the sprocket and the drive shaft.
Drive Hub for Stairmaster Steppers 4000PT 4400CL 4600CL 4400PT 4600PT...
Sep 30, 2013 | Stairmaster Exercise & Fitness
My 2002 yamaha vstar 1100 classic started and ran fine. now the starter just spins. it wont turn the engine over to start it. i already changed the battery. what could be the problem?
The one way clutch inside the motor is slipping. On the back side flywheel is a one way clutch that grabs the starter gear when the starter motor spins. It is designed to let go of the gear once the motor fires up. If the mating surface of the one way clutch and the starter gear becomes rough or chattered, it will no longer grab and turn the motor over. To repair this you will have to take off the crankcase cover and pull off the fly wheel to replace the one way clutch and the starter gear.
Apr 11, 2011 | 2002 Yamaha V Star 1100 Classic
Washer wont spin
The brake cam driver has an ear on it. They tend to break off and this won't release the brake. If that is good then you might need to check the clutch.5ff0d60.jpg Look for a thin liner or oil on the clutch. If that is the case you need to change the tranny cover seal.1c95618.jpg If that is good then inspect the main drive gear and pinion.1edfdd4.jpg These gears get smooth and won't grab.3ce3530.jpg If that is good then remove the main drive gear and look for a smashed down spin pawl. If it is smashed down it won't catch a boss under the main drive gear and spin. Training Manual
Jun 15, 2010 | Kenmore 24032\24036 Top Load Washer
Craftsman Garage Door Opener Model# 13953919 not working.
Yes replace the entire assembly. The part number is 41C4220A Sprocket and Gear Assembly and is available at Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Kenmore washer will not spin or agitate, it makes noise
Apr 28, 2009 | Kenmore 23822 Top Load Washer
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
