Question about Fagor Dishwashers
Looking to buy a second hand FAGOR FI-48BA model. Does this have a drain pump or it gravity fed?
3 Suggested Answers
SOURCE: Fagor Dishwasher FI-48w Replacement Parts
Angelo,
We are the manufacturer; Fagor Commercial, Inc. We have a network of parts distributors for our products. contact us to provide you with the most convenient one for you.
305 779 0170 or 1-866 GO FAGOR
Thanks
Posted on Jul 09, 2008
  • 20 Answers
SOURCE: Jet-Dri dispenser
wax motor opens lets out a few drops
Posted on Feb 18, 2009
Fagor dishwasher is showing F2 please help.
Not drained in time allowed (6 minutes) - washing machine fails to drain water
  • Check that filter is not blocked or obstructed
  • Check drain hose is clear of any blockage or obstruction
  • Check wiring to drain pump
  • Check drain pump is not defective
  • Check level sensor or switch
  • Check wiring to level sensor
Aug 12, 2016 | Fagor Dishwashers
Will start and run for ten mins then dies. If I wait ten mins will run again. Fuel filter is empty when it dies
Sounds like you got the wrong filter. There are filters for fuel pump tractors and filters for Gravity fed engines. I had the same problem when I changed my filter. I had to get one that was gravity fed
Oct 17, 2015 | Cub Cadet Garden
Childrenlet hot water tap running from gravity fed system, now only dribble coming out. How do we fix
Sounds like an air lock, if its a mixer tap put the palm of you hand over the tap, turn on the cold tap while sealing with your hand then open the hot and wait ten seconds then remove hand seaking tap
Nov 26, 2013 | JumpUSA Dribble Specs No Look Basketball...
1988 883 sportster hugger oil draining from oil tank to crankcase after shutdown
commen problem, could replace oil pump as pump is gravity fed and if worn will allow oil to seek into crank case.
Nov 04, 2013 | Harley Davidson Motorcycles
Air conditioner hum often
Is your AC unit a wall mounted unit or a cassette ? And do you know if it has a pump fitted or if its gravity fed drain system
Jul 08, 2012 | Goodman Heating & Cooling
1/3 hp shallow well jet pump (mastercraft brand). After power outage i have been having problems with pump. It will run continuously without building up enough pressure to cut out. It wil build up to about...
I don't think the power shortage had anything to do with the pump, I think it is the impeller or a gasket, or both. It is hard to say, a pump like that should **** dry and pull water right in.If you put your hand over the end of the pipe, it should make a mark like an octopus on your hand. I would take off the impeller, look for trouble, and replace 3 or 4 parts in there , you should have water. Hope this helps.
Sep 24, 2010 | Plumbing
Yamaha Virago 535 Fuel Pump Dead
My first question: is it ok to run the bike using only gravity fed fuel if I'm ok with a top end of only 60 mph, or am I damaging something else on the bike by doing that?
To answer your it, you fuel pumps still works and you are not doing anymore harm than possible.
**My second question: is there a way around buying the $300+ fuel pump in order to get the bike running properly again?
YES, go to a bike dismantler/wrecker who does the same tipe of bike
***My third question: WHY DOES THE FUEL PUMP COST
$300+!!?!?!??!
Well, can not answer that because I don't know....
Good enough?
Jul 24, 2010 | 1997 Yamaha XV 535 Virago DX
WHERE IS THE FUEL PUMP ON A CRAFTSMAN 20.0 HP 42" MOWER?
this is a gravity fed system as the fuel take is above the carb and the fuel drains down towards the carb and is fed with a fuel float and a needle and seat valve...good luck
Apr 07, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Angelo,
Thanks
Jul 04, 2008 | Fagor Dishwashers
Dishwashers Logo
Top Fagor Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Dennis
J.D. Browning
J.D. Browning
Are you a Fagor Dishwasher Expert? Answer questions, earn points and help others
