Question about Weller Welding Tools
Can u use the Weller universal soldering gun for making and repairing jewelry?
  • 3,000 Answers
Unless you are only interested in soldering tin/lead joints... I sincerely believe that answer to be "No"...
What kind of metals were you planning on working with
would be a GREAT PLACE to start...
and the figure out the temperatures you will need to achieve..
A word of extreme CAUTION.
Working surfaces have to be able to withstand EXTREME TEMPERATURES.
Cement will come apart with explosive force... and getting any water onto molten metal can also have catastrophic consequences... so a little supervised experience would be well advised place to begin...
Posted on Dec 17, 2016
Is there a manual for this tool - I just got it but it did not have a manual and I have never used a sodering gun before. Or is there a good website with instructions. Thanks
There are several websites that teach you how to use the tool including tips. you can go to weller .com the most important tip is once its plugged in and depending on the soldering gun. some are activated by a trigger and some are not, handle the tip with care because it gets extremely hot and can cause injury if one is not careful. if the tip is hot keep it away from anything that can ignite or flammable materials. its a good tool for making permanant wire splices, used in conjunction with tinned solder and flux. not recommended for doing pc board repair because of the extreme head produced. can also be used to shrink tubing around wire splices. good luck!
Sep 15, 2011 | Weller 120volt Universal Soldering Gun Kit...
I just plugged in my new weller 8200pk soldering gun and the tip bubbled up. doesnt seem normal, what is wrong? its the tip it came with.
Was it copper that bubbled up or just some kind of covering? If the latter, just scrape off the residue, then tin the tip as normal. If it was the first, it would have been a flaw in the copper--just replace the tip with a new one. It's hardly worth trying to get warranty on it. Hope this helps!
Dec 05, 2010 | Cooper Industries Weller 8200PK 120 Volt...
I am making jewelry with the iron....my tips are dispersing...what is my problem. Should I use a different watt. All that I am doing is soldering over copper foil to broken china.
25 watts is a pretty light iron for the kind of work you are doing, but if it works---. Tips that are just bare copper tend to erode over time (the heat causes the copper to mix with the solder and thus erode). The better tips have iron plating over the copper which protects the copper. Silver solder applied over the bare copper works in much the same way and can be applied with a propane torch. Hope this helps!
Oct 25, 2010 | Weller 25 Watt Soldering Gun Kit
My weller wsd130 solder won't work.
Try tightening the screws that hold the copper element, light corrsion can develop and make a resistance.
Feb 04, 2010 | Weller 8200 Soldering Gun
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
TRYING TO GET SOMEONE TO REPAIR A WELLER SOLDERING GUN
Try tightening the screws that hold the copper element, light corrsion can develop and make a resistance.This can cause the gun to over heat.
Dec 09, 2009 | Weller Welding Tools
MY WELLER SOLDERING GUN IS GETTING HOT AND A LITTLE SMOKE COMES OUT NOW AND AGAIN IS THERE ANYONE IN SOUTH AUSTRALIA WHO CAN FIX IT FOR ME AS WELLER SAY THEY DONT DO ANY REPAIRS ON THEM. CHRIS
these are not worth repairing as the main part of a soldering iron is the transformer which is what causes the tip to get so hot, so if yours is giving off smoke and excessive heat probably the transformer is starting to cook itself which means it has to be replaced. I would guess that the transformer will cost you more then a replacement soldering gun on ebay would cost. Hope This Helps Don
Dec 08, 2009 | Weller 8200 Soldering Gun
Weller model 550PK heavy-duty soldering gun is slow to heat up
It depends on what you say is slow, I have used weller soldering guns and desoldering guns for about 30 years. They come up to top heat in about 3min. If it is taking longer than that then there is a problem with the heating unit. You can call weller tech help number, should be on iron base and they can tell you how to test the heat unit.
Mar 24, 2009 | Weller D550PK Professional Soldering Gun...
Welding Tools Logo
64 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
