Fireice split system air conditioner serial number 040418-ID-0026 intalation date
SOURCE: Split System Air conditioner
There normally two types of leakages from the wall unit.
1.The warm air in the room when comes in contact with the cooling coil of heat exchanger (consisting of fine fins where compressed refrigerant evaporates) looses its heat & cannot retain the same moisture content at lower temperature at the point of contact with evaporator. There is a provision of a drain pipe to carry this condensed water to outside water drain. So if the drain pipe is choked or the coupling joint of the drain pipe at the bottom of cooling coil is not proper, there will be water leakage, This can be easily attended by physically looking at the fittings.
2.The second problem can be the leakage of the refrigerant. If there is second type of problem, then there will be very little or no cooling irrespective of continuous running of air conditioner. This can be easily checked by feeling the temperature of outlet air from the air conditioner.
Conclusion-As you have written that there is leakage from the air conditioner, but you have not written whether it is visible or invisible. If the leakage is visible, it is problem number 1 & if it is invisible, it is problem number 2.
If you are not satisfied you are free to ask for more explanations.
Posted on Jan 29, 2008
Johnny Reb
SOURCE: Remove and relocate split air conditioner
The simplest way of explaining this is as per the following. On your outdoor compressor unit there should be two pipes, one smaller diameter [high pressure] and a larger diameter pipe [low pressure]. Turn your A/C on inside the house and then shut off the smaller diameter pipe. Run the unit for a around 3 to 4 minutes and then check if the cooling is reducing from the unit inside the house. When you feel room temperature air [not cool] being emitted from the indoor unit shut off the larger diameter pipe and turn off unit. Isolate electrics, disconnect A/C piping and immediately seal the piping with good quality tape to prevent egress of dirt. When re-installing a quick purge of gas is usually only required to clear the lines if they were sealed properly and kept clean. Ideally running a vacuum pump is recommended but if care was taken then it may not be needed, as in many of my installations.
Posted on Nov 13, 2009
  • 81 Answers
SOURCE: Art Cool LA181CNW Split System Air Conditioner: hi, i am using an lg split airconditioner. the sp...
Sound like a defective receiver board. Have this checked. Also check to see that your remote transmits. Hold the top part of the remote to your phone or digital camera lens. press a button and a light should appear on the screen of your phone or digital camera screen.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
SOURCE: I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Posted on Oct 25, 2010
  • 59 Answers
SOURCE: replacement parts Amcor AmcorAire UCHW-H12AF2
Amcoraire USA went bankrupt in 2010. Bought out by Pridiom group. Service Dept 1-201-266-8234 or 1-201-562-9777
Posted on Jan 29, 2011
What year model is splendide serial # 012136630
Hi Tammie,
Look for a date of manufacture on the outdoor unit label, usually located near the removable cover over the electrical connections
Good luck
Feb 14, 2015 | LG LS-L1210CL Mini Split Air Conditioner
Goodman serial numbers
Serial numbers are visible on equipment where you see a permanently attached tag.
The tag will also give model number, motor amps, and other information.
Should say serial number or ser. no.
Jun 30, 2014 | Goodman Manufacturing Goodman R410A 14...
Can I get a circuit board for the outdoor unit? S# AOSAWSAMS181HX d42trivette@hotmail.com
yes ring up the company and order a new board. if its under warranty you can get it for free . give serial and model number
Nov 08, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Looking for a service manual for a Sanyo KS 3622, it is a split system air conditioner
google( sanyo air conditioning) , put parts or supplies with it and see if you cant hit something with that .. if there is a number with any of what comes up , have your modal & serial number ready and im sure you will get the manual .or they will lead you in the right direction im sure..
Aug 11, 2010 | Heating & Cooling
Need a manual for a LG split system
You should be able to get a service manual from the manufacturer online and down load it? Or go to where this unit was purchased and they should be able to help you.Get the model, serial, and product numbers from both indoor and outdoor units to take with you. The more info you have the better. The outdoor serial number shows the manufacture date.Have you removed the excess panel on the outdoor unit to see if a manual may be inside? they sometimes put them there instead of handing them to the owner. Good Luck!
Sincerely, shastalaker7
Oct 19, 2009 | LG LS-L1210CL Mini Split Air Conditioner
How can the model no. on coleman home ac, split system be used to determine specs? ex. mod. 9436G811 can be read as mfg. in 1994? and 36k btu or 3 ton for next two digits??
The mfg. date is sometimes (depends of the brand and the size of the unit) on the serial number.And the 36 in the model number means exactly what you think 36000 BTU or 3 ton.
Sep 03, 2009 | Heating & Cooling
How can I validate the tonage of my Ruud air conditioner? The model number is M0696. The serical number is RCBA-3/65AS17
you must have very old equipment are you sure of the model and serial number it might be a 69 if the serial number is the m0696. Tom double check those numbers.
Jun 28, 2009 | Ruud Matching Split Air Conditioner
Heat Pump or not???
This is an air conditioner. Based on the numbers you gave me, this is what I come up with. Thanks.
C= Split system
KL= Air conditioner
30= 2.5 ton
1= 208 230 v
D= Revision
Jun 23, 2008 | Goodman CKL49AR49 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
