What can i use to clean my front loader mashing machine dispenser pipes
  • 131 Answers
SOURCE: fridgidaire front loader washer/ problems with softner dispensor
In the back of the dispenser is a button / lever to press down to remove the entire dispenser. Remove it and take off the cover over the fabric softener / bleach chambers. You may find some junk under the cups in that cover, or in the tubes sticking up through the bottom of the dispenser.
The way this thing works is like this: You fill up the dispenser with the liquid, but that liquid doesn't get up to the top of the tubes. When it's time to dispense, the washer adds water to the appropriate chamber, raising the level to above the tube. The liquid then goes down the tube, creating a suction which (ideally) draws the rest of the liquid up into the cup, over the edge of the tube, and down the dispenser. The washer will add water several times to accomplish this. The system isn't perfect, but it usually works with few moving parts.
If the fabric softener is especially thick, it will have a hard time getting siphoned down through the tube. If it looks as thick after the wash as it did before the wash, the machine isn't adding the water to the cup. I believe on the Frigidaire, there's a separate valve (all part of the same valve assembly) for each dispenser chamber. If it isn't adding the water, you'll have to replace the whole valve assembly.
Posted on Mar 12, 2008
  • 188 Answers
SOURCE: he2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Posted on Feb 21, 2009
Samyfam
  • 378 Answers
SOURCE: water leaks from my detergent dispenser from my
This is usually indicative of soemthing blocking the flow of water out of the soap tray, down the connecting pipe and in to the drum chamber.
The soap tray doesnt have any seals as water should just flow into the tray, wash out the soap / fabric softner, and then flow out the back of the tray and down the connecting pipe. When working correctly, there is no pressure or water back-up to cause the water to reach the front of the soap tray.
Take out the tray - your machine user manual will show you how, and check both the tray itself and the "hole" it slots in to for either a build up of solidified soap powder, or some other foreign object. If still leaking, remove the tray again and try to get your hand (a woman's or teenager's hand being smaller is best) down the large oulet at the back of the "hole" the tray slots in to to feel for a blockage.
Do you have young children ? A washing machine soap tray is a great place to hide things !
Occasionally, if the smaller pipes that deliver hot and cold water to the tray come adrift, this can spray water at the front of the machine. This water then has only one real way out - via the soap tray "hole". Most often this will be the cold water pipe as this has higher water pressure to cope with. The only way to check this is to take the top of the machine off.
If after all of the above it still leaks, you'll either need to dismantle the machine enough to see the back of the soap tray "hole", connecting pipe and drum chamber for a better look for problems, or call an engineer.
Posted on Nov 04, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on May 26, 2010
SOURCE: conditioner remainig in dispenser
Same thing happened to mine. I stripped the drawer out and found that the small syphon tube which sucks the conditioner out of the drawer was blocked with a jelly like deposit. Stripped the syphon down and cleaned it all out and it now works fine again.
Posted on Jun 06, 2010
Leaking washing machine
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.
If helped, click.
Apr 14, 2013 | Indesit Washing Machines
Lots of water pouring out on to the floor from the laundry soap dispenser in my front loader and doesn't say any error and when i start it pours out
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Apr 03, 2013 | Samsung WF328AAW Front Load Washer
Water leaking out of soap dispenser?
Mar 17, 2013 | Washing Machines
Simpson front loader washer leaking from front soap drawer on the spin and rinse cycle when filling
Mar 10, 2013 | Washing Machines
I need to remove a drawer front for cleaning.
If this is a front loading washing machine..................Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
If helped, click.
Mar 02, 2013 | Refrigerators
After the cycle is complete our Whirlpool Duet Front loader washer leaves liquid detergent in the wash tub and the dispenser. Please let me know your thoughts? Thank you.
it might be that one of your water valves have gone or the filters are blocked on the water inlets( try this first turn your water valves off at the the tap end take the cold pipe off at the back of your machine and there are little gorse filters in the pipe or water valve take them out and clean put back do the same to the hot and try the machine on a wash let me know if this has helped
Nov 12, 2011 | Washing Machines
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
I have a front loader WFS1071AW 7.5kg and it leaks loads of water and suds from under the detergent tray when filling. What is wrong with it???
The hose down from the back of the dispenser to the drum is blocked.
Take out the soap drawer and use a babys feeding bottle brush to clean out the pipe
Either that or take off the top of the machine (Normally two screws on the back of the top panel)
Then remove the pipe and clean it you may need a pair of Corbin Clip pliers to do so , at a push use Mole Grips
Jul 08, 2009 | Whirlpool WFW8400TB Front Load Washer
My Frigidaire Affinity front loader smells like mold
have you cleaned the main waste pipe as this surpisingly enough gathers a lot of gunk and in warm weather makes it smell,i say this cus we expeirieced this and i replaced rather than cleaned the waste pipe,worth a try it worked for me,rgds paul
Jul 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
I want to clean the dispenser.
pull dispenser out onleft rear corner is small tab push it down and pull drawer all the way out..also be sure to clean area inside dispenser top and bottom
Nov 09, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
