Question about Goodman Heating & Cooling
What is the BTU rating for Goodman model GMS90703BXA?
  • Goodman Master
  • 3,315 Answers
IF you take the front cover off there is a data badge inside which will give the input in btus .
Posted on Dec 17, 2016
Btu rate model ckl49-il serial 0506103005
Built in June of 2005, it has a BTU rating of 49000 BTU or 4 tons. This is a 12 SEER, R-22 cooling only unit.
Aug 10, 2014 | Goodman Heating & Cooling
Would like to know many BTU input my furance has?
It is on the data badge on your furnace or in the manuel
Apr 13, 2013 | Goodman GMS90703BXA Heater
I need to know how many BTU in-put this france has?
remove door panels.....btu's are listed within the rating plate
Very small amount of gas leaked from vent hole on gas valve for my Goodman 50,000 BTU furnace (LP gas) then stopped. What is the vent on the gas valve for?
Hello, peter, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
Let me know, Mike
Sep 27, 2011 | Goodman GMS90703BXA Heater
I have a Goodman 3 ton 70,000 BTU gas furnace that has started making a rattling noise from a small fan with a 1/4 " rubber hose leading away from it. I was told that it has something to do with...
its the fan which takes the fumes up the flue its the combustion fan the hose goes to the pressure switch you will need make ,model, serial number of heater btu input , you can replace this your self just swop like for like , try looking on line for a price .
Dec 06, 2010 | Goodman GMS90703BXA Heater
I have a Goodman high-eff furnace, 115 BTU/hr. The fan runs constantly but it has stopped blowing warm air. I'm getting 6 flashing lights as error code. What's this mean?
Remove the lower panel and look for a wiring diagram pasted to it. On that diagram there will be an error code diagnostic chart. Depending upon which model you have it could be an open overheat switch caused by a dirty filter or a bad fuse.
Feb 13, 2010 | Goodman GMS90703BXA Heater
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
BLOWER CONTINUES TO BLOW COLD AIR AFTER REACHING DESIRED TEMP.
There is a little switch on the circuit board. Look closely at the wiring diagram and it will indicate which switch to adjust. If not, review the operating manual for details.
Nov 24, 2008 | Goodman GMS90703BXA Heater
Ck36-1a
If the coil you have is rated at 30,000 Btu's and the condenser is rated at 36,000 Btu's; chances are it will work. However, make sure you have very good air flow thru the coil or things will freeze. If you can get the correct 36,000 Btu orifice to fit the coil, install it. Better yet, Install a 3 ton TXV (Thermal Expansion Valve).
Sep 14, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
24 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
