My name is Roberto Cruz My magic jack number is ************ and I need to cancel an order on the way with a new device
The order on my way to be cancel is TS70831830 and the order date is 12/15/2016
Why is my number changed when i renewed
3. Internet Communications Feature
a) Incoming Calls
When you first register your Device or download the magicApp, as part of the available features, you may elect to choose a unique phone number. YMax is the provider of your phone number and/or inbound calls. An annual fee may apply. The phone number chosen will be allocated provided YMax determines that it is legally permissible. If you are eligible for a phone number, it will be allocated to you as soon as reasonably possible after YMax has received your request. YMax may use customized ringtones or ring back when completing your calls, including supplying various messages of different lengths. YMax does not guarantee that a requested phone number can be allocated to you or that you can make use of the incoming call feature. The allocation of a phone number to you does not constitute any transfer of title, ownership, license or other rights with regard to the phone number. If you transfer or port out your Service phone number, your Service is terminated and you relinquish all claims for a refund of your initial licensing period as well as any renewal licensing purchased. YMax may, without any liability, refuse, change or terminate any phone number at any time. If YMax changes the phone number that has been allocated to you, YMax will notify you, stating the effective date of the change and your new phone number. If you do not wish to accept this new phone number, you are entitled to cancel this Agreement; however, you will not be eligible for any refund unless you terminate the Agreement within 30 days after purchase of your Device and qualify for a refund as further described in Section 2 of this Agreement. We will not be liable for any damages resulting from the change of the phone number.
GetGet Live Help HERE.
International VoIP Phone Service Customer Care Support magicJack
Jan 05, 2016 | magicJack Plus
I would like to cancel my magic jack
not from this page
you will have to contact your supplier direct and make the arrangement
Dec 29, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
How do I access to my magicjack number (239) 205-4793. My name is Socorro Giacoman. E-mail: giaco11@aol.com
Recommend contacting customer support for a fast resolution to your issue: http://www.magicjack.com/index.html?utm_source=google&utm_medium=cpc&utm_term={keyword_text}&mkwid=s0oEqngPJ_dc&pcrid=54294996729&plc=&pkw=magic%20jack%20customer%20service&pmt=e&cvosrc=ppc.google.magic%20jack%20customer%20service&utm_campaign=Branded+-+Exact&utm_adgroup=Magic+Jack+Customer+Service&gclid=Cj0KEQiA1NWnBRDchObfnYrbo78BEiQA-2jqBbxMBi_AvBczHuoy1NP0_h7PP13QA9mnndS4kWtvBQUaAgaf8P8HAQ
Mar 03, 2015 | Computers & Internet
H0w do i get an existing magic jack to work, i had to buy new computer but now when i log in it asks for pin number. There was never a pin number
Use Magic Jack's Live Chat feature and they will set it up for you. Click the link or type the link into the address bar at top of browser http://magicjack.com/techchat/
Jan 02, 2015 | magicJack Usb Phone Jack - As Seen On Tv
I'm having problems getting my old home number to my magic jack
To switch a phone number from one company to another, you need to request your new phone company (magicJack) to "port" the number from your old company.
The key to making this work is that you can't cancel the old server until the porting is complete. After magicJack has ported the number, and you've confirmed that it's working, that's when you can call your old phone company to cancel service.
Oct 22, 2014 | Computers & Internet
Magic jack customer service
Well, you'd best go to Magic Jack's web site, and either log in to your sister's account and cancel it, or try to find a Magic Jack customer support telephone number and make the call.
Aug 22, 2014 | Computers & Internet
Magic jack contact number
First is your internet connection working Ok? If so then unplug and remove any software from your machine. Next plug it back in. It should act as a new install. Lucky you upgrade then should come up. If not go to http://mjcheck.low.li/ and download the firmware. It will have to restart but should work after that. If not repost. good luck.
Happy MJ user
Mar 17, 2014 | Computers & Internet
Magicjack problems
Try another telephone as the magic jack device only provides a certain level of voltage output which does not supply enough power for a dial tone and power to older telephones. There are work arounds provided within the magic jack forum blogs which can be found by visiting this website, found on google.
Dec 22, 2013 | magicJack New & Improved 2012 Plus Free...
I have majid jack I want to re new it please help me
Hi Firdouse,
I just had to do this yesterday:)
First you need to login to the Magic Jack account. www.magicjack.com
Go to the (Phone Numbers) tab
In the menu, you will see (View-Renew-Add), select that.
When the Magic Jack Devices screen shows, you will see a column that says (Device Status).
Under that column you will see the date it expires and (Add Years). Select (Add Years).
It will then give you the option to renew your subscription for 1-5 years.
Thanks, Hope this helps.
Please Rate
Gary
Jul 30, 2013 | Harley Davidson Harley-Davidson Motorcycle...
My computer doesn't recognice the MagicJack
Magic Jack reserves the first empty drive letter number after your hard drive letters. The problem is that it cannot share this drive letter with a flash drive -- in that when Magic Jack is out, some newer flash drives (such as 4GB Kingstone DataTraveller) cannot claim the same letter, and therefore the flash drive does not work. The reverse is true also in some cases too. if you plug in an older flash drive that uses say letter G when G had been previously claimed by Magic Jack, and you click on the Magic Jack icon (tha references G at this time) the Majic Jack stops working on that PC for good. This seems to have come up recently (late June 2009) withthe Magic Jack's new software update. The annoying beeps also have been introduced with this update. Somthing enters digits into Magic Jackphone number dialing buffer that looks like a memory leak from another part of the computer RAM due to poorly written drivers or invalid shared interrupts or DMA regions.
[Randy Rasti]
Jul 08, 2009 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
