Question about Dryers
Hi, after oyster light securing screws for 4 blade ceiling fan model FB48-WHT-R4C10YS app no N14332 and ceiling fan no 0274137-HD. No other markings on the ceiling fans
SOURCE: broken globe on Hampton Bay Ceiling Fan (Vercelli model HD278017)
My fan just stopped working - no lights no fan :( and I just can't seem to find any type of switch - only the remote, which lights up just fine. Can anyone help???
Posted on Jun 08, 2008
  • 13 Answers
SOURCE: Broken ceiling fan switch
home depot, Ace, true value cary rhem, probably better quality, doesnt sound like the one aloha uses are very rugged
Posted on Jan 27, 2009
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
SOURCE: I need to remove my hampton bay ceiling fan from the ceiling.
im trying to install light to ceiling fan but the wires are a different color and light wont come on
Posted on Oct 16, 2009
SOURCE: I have a futura Model LD140129L-SL ceiling fan and
The white glass turns independent of the silver surround in an anti-clockwise direction about one quarter turn, that is the direction the fan spins in the summer direction, pushing air down. It has three metal pins that fit into tapered slots in the glass cover. Once it has turned it should drop down. If it is stuck, get your safety glasses and a small hammer and just smash the bloody thing, when you buy a new bulb, buy a new light cover.....
Owen In Oz
Posted on Sep 26, 2011
The motor is not stable-therefore it bounces around & doesnt work-I believe it was assembled wrong I need directions for putting together
Goto a hardware store and purchase a balance kit. Follow the directions in the kit to balance the blades. Also make sure all the blade screws are tight, all blades have all the washers on them and that the motor is securely mounted to a FAN box. Regular light boxes often cannot hold the weight of a ceiling fan. A fan box has braces on it that expand into the ceiling joists.
Jul 19, 2016 | Dryers
Minka f502 is noisy - how do you tighten the screws that attach the fan blade to the motor hub?
With a screw driver? And perhaps you also clean all blades. Sorry if you already did that.
Mar 16, 2015 | Minka Aire Ceiling Fans Gyro Traditional...
Need a 42" white ceiling fan blade
I would need to know what fan ( make/model) you have. Is the blade broken or the blade holder?
Apr 12, 2013 | Dryers
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Sep 28, 2011 | Dryers
Size of screws to mount fan blades
mcdevito75 here, A large hardware store like Home Depot, Doody's should have a standard kit of screws for the fan blades of most newer ceiling fans.
Jul 27, 2010 | Heritage Hugger White Ceiling Fan
In general, the steps are:
1. Turn off power at the breaker -- not just the light switch.
(There are still "hot" wires in the junction box when "Off".)
2. Take out any light bulbs.
3. Remove any light globes. Some screw in, but most are held by springs so just pull gently with a bit of force.
4. Remove fan blades. Most have a spring at the inside edge of the blade -- press down on the spring and push the blade toward the fan motor.
5. Remove the ceiling mount cover. There is usually a circular ring up next to the ceiling; just twist it off with your hands ("lefty - loosy, righty-tighty").
6. Unscrew the ceiling mount screws. Usually there is one or two in a "simple" hole, and two one "sliding" slots. Take out the "simple" screws, and loosen (but don't remove) the "sliding" screws. Be careful not to drop screws or washers into the fan motor.
7. Twist off the ceiling mount cover to expose the wiring.
8. Disconnect all wires. For safety, put a wire nut on the wires from the ceiling.
9. Tip the fan and remove it from the ceiling mount. Keep in mind that the fan is pretty heavy, and you're on a ladder!
NOTE: Be careful not to put any pressure on any of the blade holders, especially if you intend to re-use the fan. If you do, the blades will wobble.
10. If you're installing a new fan, you can probably re-use the mount. If you want to put up a simple light fixture, remove the mount by unscrewing the two long screws holding it to the junction box.
Jul 17, 2010 | Hampton Bay AC414-LRU 52'' Kemper...
52in nassau indoor/outdoor fan 129-909 floor model no instr
white definately goes to white. however you configure the red, black and blues will only determine which switch on the wall controls the fan or light. as for the bare copper, the fans typically come from the factory with a green pigtail screwed into the top of the downrod
Aug 17, 2009 | Hampton Bay 24002 Ceiling Fan
2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Jan 21, 2009 | Solar 2-wire Pull Chain Light Switch For...
Ceiling fan woobles on high speed
Turn off fan, then check to see that all of the blade mounting screws are tight. (check blade to blade arm and blade arm to fan body screws/mounting mechs.) If none are loose, you can purchase a blade balancing kit from most hardware stores, including Home Depot and Lowes. Let us know if this helps or the cure you come up with.
Aug 23, 2008 | Hampton Bay 24002 Ceiling Fan
Ceiling fan
If the fan blade mounts are removable, go to your local hardware store with one of the mounts, and find some screws that will fit. You might not be able to get the same color, but if you check a few stores you should find something with the right shape of head to fit snugly.
Apr 17, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Dryers Logo
37 people viewed this question
Top Dryers Experts
