Question about Amazon Tablets & eReaders
How do you check the battery on a Kindle? - Amazon Tablets & eReaders
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Amazon Master
  • 102,366 Answers
Tap the gear icon at the top, select "More" then select "Device".
Posted on Dec 17, 2016
  • Marty Alberda
    Marty Alberda Dec 17, 2016
    But if the device is completely dead and won't charge how do you check the battery?
My kindle won't charge. I have tried 3 different chargers.
Lillian, May have to try hard reset or possibly repair charge port to get battery to start charging. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My Kindle won charge
Kindle Wont Start or Charge How to Reset Kindle
Troubleshooting Kindle Fire That Won Charge
Kindle Fire Won Charge Fix
May 22, 2016 | Tablets & eReaders
Where can I take a kindle fire to get battery replaced
Amazon Kindle Fire HD
Kate, The source, radio shack, computer repair store or even a friend that is some what knowledgeable about computers. Kate you can even google search (Amazon Kindle Fire battery replacement) and maybe do it yourself after watching video or reading guide. Check the attached links,instruction and guides, Good luck
Good Luck.
How to Replace Your Amazon Kindle Fire Battery
Kindle Fire Battery Replacement
Kindle Fire HD 8 9 Battery Replacement
Apr 05, 2016 | Amazon Kindle Fire HD
My kindle fire loses it's entire charge overnight when turned off. It occasionally makes a beep
Amazon.com: Customer Discussions: battery life on kindle fire hd
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Nov 12, 2012 - My son bought himself a kindle fire hd over the summer and we are having some issues with ... and unused yesterday from a full charge and it was < 5% (red battery) last night. ... a paperwhite kindle as its much lighter and I'm fed up losinghours to addictive .... ETA I tried again last night to power off and charge overnight. Kindle Fire HDX 8.9 battery ...
Dec 3, 2013
Kindle Fire HD won't charge?!
Apr 10, 2013
Kindle - Losing charge when ...
Oct 9, 2012
Kindle Fire HD Battery tips
Sep 17, 2012
More results from www.amazon.com
Dec 09, 2015 | Tablets & eReaders
New battery for Kindle Fire?
Step 1 - Back Case
  • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
  • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
  • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
Step 2
  • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
Step 3 - Battery
  • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
  • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
  • step 4
  • Repeat the process from the previous step to free the left battery cell.
Step 5
  • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
  • Pull the battery out of the Kindle Fire.
Oct 31, 2015 | Amazon Kindle Fire HD 7in, 32GB
What is the life off a Kindle?
You will need a New battery, and electronic contact cleaner, or more and like a new Kindle ?
Sorry
May 11, 2015 | Amazon Kindle Fire HD
My kindle wont turn on
There might be some issues with the Battery or the Kindle Device. In the last check the charging port of your device. May be kindle do not charged alternatively you can call the kindle support. Kindle Technical Support Registration 877 690 9305
Aug 06, 2014 | Amazon Kindle Fire HD
Kindle will not turn on
The Kindle Fire will not turn on, correct? Let's try a hard reset.
Step 1: Unplug the device from the charger
Step 2: Press and hold the power button for 30 seconds
Step 3: Release the power button, then press and release the power button normally, the Kindle should wake up
Step 4: If the Kindle does not wake up, find an alternate charger or go down to Radio Shack or Staples and get a new charger
Step 5: Plug in the new Charger to the Kindle for 12 hours when done leave the Kindle plugged into the charger
Step 6: While the Kindle is plugged into the charger, press and hold the power button for 30 seconds. Let the Kindle charge for another hour.
Step 7: Pickup the Kindle, press and release the power button normally, the Kindle should now wake up.
Step 8: If the Kindle does not respond, contact Amazon for a replacememnt
Apr 21, 2013 | Amazon Kindle Fire HD
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
My kindle got wet by a big wave in the ocean won't turn on any suggestions
Check if your battery has any voltage.
Try a different charger or try to power up your Kindle with a different battery. If that fails too, you have a logic board issue. Amazon2_bing.gif should give you a replacement. If you're out warranty, you can try to open it up and clean any corrosion you may find inside. If that fails you need a new logic board. You can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Nov 14, 2009 | Amazon Kindle 2
Tablets & eReaders Logo
Top Amazon Tablets & eReaders Experts
castletech
castletech
Martin Murray
Jax Planet
Jax Planet
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
