How do I connect my TV to blueray - Televison & Video
  • Televison & ... Master
  • 3,895 Answers
Plug blueray device output into hdmi input of tv and then change input select on TV to HDMi 1 or HMDI 2 or HDMI 3
Posted on Dec 17, 2016
How to connect netflix with sony blueray disc player?
Switch on the blueray player. Switch on your TV set. Connect your blueray player to the TV with an appropriate cable. Press HOME on the blueray player. Navigate with the blueray player remote control to NETFLIX and press OK. After a few seconds NETFLIX should start.
Jun 22, 2014 | Netflix
DVD Player Quick Connect Tips
There has been a lot of confusion lately about how best to connect your new DVD or Blueray player to your TV set. For many this has been a nightmare since the introduction of the new Component and HDMI versions of Higher Priced DVD and Blueray disc players.
Remember that your new Blueray player will play DVD's as well as Blueray Disc format movies.
For the common connection that most people use, there are only 3 wires to consider. Yellow for Video, Red and White for Stereo. Always use the line out jacks on the back of the player to connect to the TV. Use the Line in (Video In) jacks on the TV set.
The only thing to remember here is to match the colors exactly and select the video source from your TV remote control. If all those numbers and buttons are confusing to you, just memorize where your Source button is on the remote, and choose one input at a time until your DVD welcome screen appears.
The next higher quality Video source will be the component Video outputs on your DVD or BlueRay player. These will be Red, Green And Blue.
Also note that you will need a red/white audio cable for sound with these connections since the component outputs only transmit Video.
You will be able to see the audio connectors close to the red blue and green component outputs on most players. All connectors on your player will be outputs, unless you bought a DVD recorder and player.
We will reference only the player type at this time.
As mentioned before, you only need to match the wires from the DVD or BlueRay output to the exact input connectors on your TV, but now the audio connectors need to be used as well.
Component to component cables/
Stereo Audio Cables/
Use your source selector on the remote as before to View your movie.
The easiest connector to hit the market so far is the HDMI version, which combines the Video signal as well as the audio signal into a single manageable cable. If your TV set doesn't have this connector you will need to use one of the above methods to connect your system.
To use the HDMI you need only plug it in to the connector designed for its use on both the TV as well as the player.
There is very little chance you will connect this to the wrong port, but just in case your HDMI TV and DVD/Blueray player are equipped with an Optional USB port, you should read the panel closely to be sure you have the right port. Remember, these connectors should never be forced on. If they are too tight to connect, you may have chosen the USB port by mistake.
Thats my Tip o the Day
Please Vote for this Tip if you found it helpful.
Bob S.
on Mar 23, 2010 | Audio Players & Recorders
Picture tearing at bottom
Have you tried changing the output video settings of the Blueray player from NTSC to PAL or vice versa? Also check that Blueray has HDCP turned on or off, depending on your TV set.
What's the make and the model of the TV?
Jan 01, 2014 | GE Televison & Video
It wont play bluerays i think it needs a update? how do i update it?
A TV doesn't need updates to play Blueray. Just make sure the Blueray player is set to an output that the TV can handle such as 720p, 1080i or 1080p. If you have it set to 1080p and the TV is not 1080p you will get a blue or a blank screen.
Aug 28, 2010 | Televison & Video
My HDMI connections aren't working. How do I
Tries unplug and replug the tv back about an hour.Let the tv reset itself back to factory setting.Now go in ur menu go to PICTURE.Go down the menu pick reset,that to reset all the funsctions in the Tuner board.This process should get all the HDMI Hub. working again,not than ur Tuner board have all the HDMI Hub. are shorted and dead.
Apr 27, 2010 | JVC LT46FN97 46 in TV
Vizio tv has no sound.
I had a similar issue with my VF551xvt and my Blueray player. The issue was actually with my Blueray player and not the TV. the settings for the blueray player when hooked to HDMI were defaulted to muted. once this was changed my sound came back.
Jan 17, 2010 | Vizio VF551XVT 55 in. HDTV
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Oct 24, 2009 | Bose Audio Players & Recorders
I have a blue ray DVD player and want to connect this to my bose lifestyel 48 system. Do I just connect the blueray to the TV but connect the audio from the blueray player into the Bose AUX ? if I do that...
Yes, that is what you need to do. Connect the BR player direct to the TV and send the audio to an input on the BOSE. Of course any audio you pipe through the BOSE will be processed to their specs. One day they will catch up to HD and BR!
Aug 15, 2009 | Bose Lifestyle 48 System
Having trouble connecting my blue ray and tv to my yamaha receive and surround system
Must be an HDMI ?
If yes use the HDMI DVD input on your receiver ( from the Blue Ray using a HDMI cable )
Then use an HDMI cable from receiver to TV.
That should work for image. Sound would only work directly from TV, to have sound on receiver:
Use either optical or coax cable to direct digital sound from blueray to receiver.
Best is optic, depends on blueray or cable availability ... Coax = RCA cables @ 75 Ohms, use of a spare RGB would work find (using only one of three color available let's say using Red only) or try with any RCA cable.
direct cable from blueray to receiver ( Digital inputs at far left looking back of receiver num 7 in owner manual, choose DVD )
If no sound from receiver check Audio select from option menu ( set to auto )
Any specific question about this procedure ?
or guess you already found out,
Enjoy :-)
Dec 17, 2008 | Yamaha RX-V363 Receiver
Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Nov 22, 2008 | Sony Grand WEGA KF-50WE620 Television
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
