TX-NR747 When I have it set to cable/sat it starts, comes up with dialogue norm-3 then all audio shuts off, if I turn the tv off audio comes back on
SOURCE: picture is snowy/dark
update: Well, we ended up calling the repair man and we had a bad Y-sustain board and also a bad Z-sustain board. According to the guy who fixed it, it was due to over use of the TV and using main power button instead of shutting off through the cable remote. 650.00 later and a few weeks later, we now have a fixed plasma. No real suggestions on how to get more life out of the new boards.
Posted on Oct 08, 2007
  • 121 Answers
SOURCE: Audio comes on but not video.
unfortunately, i have the same problem but i found out that it's natural for the flat panel's to do that especially if you are using the hdmi input... wait 10secs b4 turning it on again.. it's bc if using the hdmi input, it takes a sec to change it's signal over and sometimes it blanks out and only audio comes in..
if you still have a warranty on it, contact them to confirm it's not something else going on.. my cable guy helped me with that ? and more since we are new to flat panels.. i hope this helps..
d
Posted on Feb 29, 2008
bestdarngood
  • 3037 Answers
SOURCE: Follow up on HDMI Issue
so you can choose 16:9 which is what you want correct? When you choose it on the tv, it resets after turning off correct? or does it have a black bar around the picture?
So if you set both to 16:9, then both change back or just the cable box?
Posted on Mar 31, 2008
freetek
  • 5568 Answers
SOURCE: VIZEO LCD turns off or picture pulses
I can't say that this is the problem, but the behavior is that of a failing solder joint in the power supply; these tend to be intermittant and random. Most semiconductors just flat die under the right conditions but it is possible for a power semi to fail internally exhibiting just the same behavior. Since both audio & video are down together, I would check the main power supply first.
Yours may be separate from the lower level electronics and user replaceable. You won't hurt anything if you pull the AC plug overnight, remove the back panel and look inside to see if you have a separate board with larger components on it; cylindrical ones (capacitors) and largish blocks (transformers & chokes). If you find this, check for a part number or have the set's model number handy and call the mfr.s service to ask about repair or replacement costs. You can ask them too, if my diagnosis sounds right to them.
Posted on May 05, 2009
Testimonial: "The information was helpful but I could not see if there was a bad solder Joint in the power supply. The TV worked well after that incident. "
roety
  • 585 Answers
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 11, 2009
Testimonial: "A very good solution, right under my nose. Thanks!!!"
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
Onkyo receiver is not starting up hdmi from receiver to tv
run an HDMI cable from TV direct to DVD or other HD source instead of going through Onkyo. If it works, you have a bad HDMI output on the Onkyo. If not you may have a bad cable or a bad port on TV. Then try a different HDMI input on TV.
Jan 15, 2013 | Onkyo Tx-nr616 7.2 Thx Certified Network...
[TX-DS595] My Video 1 stopped working, no audio, (Right before the super bowl!) yet I get audio on DVD & Tuner. What could be the problem? Thanks, Ira S. Cohen
Well, what's on Video 1 and is IT okay?
You don't say if you're using the analog audio associated with Vid 1 or if you have digital audio coming in and assigned to Vid 1. Check the cables. If using the optical, make sure it has no small-radius bends.
If analog audio, try another input - video 2 or 3.
If you have Cable/SAT TV as the source, what's going on with ITS audio settings?
http://www.retrevo.com/support/Onkyo-TX-DS595-Receivers-manual/id/365dj195/t/2/
You can always run that RCA cable pair from the source to theTV as a test for audio, too.
Feb 05, 2011 | Onkyo TX-DS595 Receiver
Onkyo TX-SR601 6.1 Channels...dialog norm -3 readout
Enter the menu for speaker levels, and increase the center channel.
Dec 07, 2009 | Onkyo TX-SR601 Receiver
Onkyo TX-SR604 provides audio thru receiver but no video on Bravia LCD when satellite receiver signal is sent thru any of the Onkyo HDMI connections to tv, however if I connect up my Samsung DVD recorder...
easiest fix is to take all hdmi straight to tv. then come out of tv with optical cable to your receiver. that way what ever your watching will automatically be sent to the receiver thru optical. you even will get dolby dig. also you can have audio from your tv when you dont want to use your surround. keeps receiver on one input also.
Jul 02, 2009 | Onkyo TX-SR605 Receiver
Audio problems
Good Day, corilyn;
Several things that you may try:
1. Unplug TV and Cable/Sat box for 3-4 minutes, plug all back in, that's resetting the devices.
2. Some boxes have volume controls, make sure 'box' volume are turned to max.
3. Go into TV's customer menu, go to audio section, make sure speakers are turned on/ set to internal speakers.
Good Luck, Big Irish.
Jul 08, 2008 | Sony Televison & Video
Sound control is via TV remote only
You didnot mention wehther you selected external speakers on you tv. If your TV allows this then do that, first.
Also the sound input to your TV must come from some source, (cable/ Sat). You could remove the audio inputs to your TV and only allow the audio to go to your Receiver.
RCA cables will allow this to be easy just remove the red and white audio to your TV. If you have sent them to your reciever then you must balance the cable box volume (reduce to the lowest level , then raise your recievers vol until satisfied if you are to loud when you switch to a CD then raise TV vol until they match, so your CD doesn't play to loud when switching modes)
If you are using an HDMI cable to your tv than there has to be a setup for turning off the internal speakers on your TV.
Dec 03, 2007 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
