Auto set up for channels over the air TV wont memorize the channels after auto program
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Posted on Dec 17, 2016
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
Cannot get picture or sound but can get menu screen wont select or memorize channels on cable
this TV will not tune modern cable signals. You must use a set-top box with a TV that is this old.
Feb 14, 2015 | Mitsubishi VS-8087 80" Rear Projection...
Polaroid tv keeps rolling from ch. to ch.
Check whether the micro-switch [Channel up/dn] have struck or not. This might cause the TV to jump from channel to channel. Refer its user manual and make an auto search for on air programs. If the do not memorize any of the channels, the fault is with its main system memory IC.
Aug 01, 2012 | Polaroid 1720-7 Remote Control
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
on the TV screen.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
channel reappears on the screen.
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
What buton do press to get the channels?
Hello
To tune the TV either with cable of trerrestrial antena, plug in the cable or terrestrial antena cable to the antenna socket of the TV and do the following.
on the TV screen.
channels.
OK.
Dec 16, 2010 | Emerson EWF2004 20" TV
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
I have a Disney Princess 13" color television, and I cannot get cable channels to work. I read the insturction manual, but get confussed at "ATV AIR" or ATV CATV" or "DTV AIR" or "DTV CATV"..I did hit...
Need more details. Is it an hdmi hookup or a coaxial? Is your cable line hooked up directly to the TV or are you using a modem? Is it a smart TV or just regular?
Jun 13, 2017 | Disney Princess TV/DVD Combo
Trying to hook up the tv to direct tv, don't have remote and cannot get tv on to channel 3
The only work around you have without a remote is sloppy. If you are patient, give it a go: connect the box to the TV (cable/ant input), turn on the direct TV box, using the TV button panel (here comes the sloppy) fumble your way to the auto-program menu, start auto program. When the auto-program is done, you will have just CH 3 memorized, so the CH -/+ button will only go to that channel. Worst part will be figuring out the buttons on the TV... it can be frustrating. It may take a few tries, that's why I call it sloppy. I hope this was useful, best wishes.
Apr 19, 2010 | Insignia NS-24 TV TV
Not all channels memorized during setup
YOU WILL HAVE TO PUT IT IN THE CABLE MODE BEFORE AUTOPROGRAMMING. IT IS IN THE MENU RIGHT BEFORE AUTO PROGRAM
Aug 17, 2009 | Toshiba 23HLV87 23 in. LCD Television
Mitsubishi ck3526r
I feel your frustration! Most all tv's share similar features,but
access varies with mfr & age.Some sets have an individual channel add and erase system as well as an auto-program
method.Others offer only one way to memorize.In your case,
analyze how to erase channels and thus learn to memorize!
If you need more help,please let me know in exact detail the steps you are taking......T.
Oct 25, 2007 | Zenith SY2751Y TV
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
