Question about GE Refrigerators
Where is the timer located for a ge fridge TFX20JRSA
  • GE Master
  • 16,688 Answers
Your parts diagram for the TFX20 is on this page
My TFX20JRBKWW Model Overview from PartSelect ca
Posted on Dec 18, 2016
DEFROST TIME CLOCK GE GSH25J, WHERE IS IT LOCATED?
Hello:
Your model does not have defrost timer, instead the defrost is controlled by Main control board located on the back of the fridge..
Part # WR55X10942
PS.. Most common defrost problem on this model is not the board. Its either defrost heater or defrost thermostat..
Jul 15, 2017 | GE Refrigerators
Where is the defrost timer located on model GE GSS22JETG WW? This is a side by side
USUALLY LOCATED IN THE FRIDGE AT MIDDLE TOP BUT SOMETIMES CAN BE FOUND IN THE FREEZER ALONG THE WALL
Mar 08, 2015 | GE Refrigerators
Wherfe is the defrost timer on the GE PSS25ngmww.is it part of the mother board
sometimes the timers are located inside the fridge side by the light or on the electronic board in the back of the unit depending how old this is.
Dec 16, 2013 | GE PSS25NGM Side by Side Refrigerator
Ge profile refrigerator PSF26PGTB defrost timer
your defrost timer on this model is an ADC type timer(automatic defrost timer) and is located on the mainboard in the lower rear on the back side of the unit,its part # is WR49X10152
Aug 25, 2012 | GE Refrigerators
Where is defrost timer located
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
You can post your model number into one of several appliance parts sites on the internet and search for defrost components to find your parts.
Jan 14, 2011 | GE GSS25JFM Side by Side Refrigerator
Where would i locate defrost timer on my ge bottom freezer refrigerator
Older fridges use a defrost timer to control when the fridge goes into defrost. Yours is a newer model and uses a control module which controls all of the fridge's functions including defrost timing. It does not have a defrost timer. It cost around $150. But I would check the defrost element first. A lot of problems with the defrost are usually a burnt out heating element. Use a meter and check that the element is not electrically open.
Dec 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
After unplugging and defrosting my ge tfx20nw it
Good day,
The defrost system has failed. It is made up of a timer, defrost thermostat, and defrost heaters.
The timer is located behind the light guard in the fridge compartment.
The heaters and defrost thermostat are located in the freezer compartment, behind the back wall.
To test,
1. With the machine running, in the fridge compartment, pull off the thermostat knob, and then unclip the light guard.
The timer is behind the panel exposed, but has a hole to insert a small screw driver to advance the timer.
Turn the timer clockwise until the machine shuts off. Wait 45 plus minutes. If the machine turns itself back on the timer is good.
If not, remove the panel, and install a new timer.
2. If the timer is O.K. then the problems are in the panel on the rear of the freezer compartment.
Unplug the machine, and remove the rear panel. Allow it to defrost.
There are two quartz radiant heaters, one located on the bottom of the evaporator coil, and one half way up. There is also a defrost thermostat clipped to the top of the evaporator. It is a round disk about an inch in diameter.
Purchase and replace all 3. You may need wire nuts to splice wires together so purchase them as well, when getting the other parts.
Go slow, the heaters are easily damaged or broken if handled roughly.
Dec 15, 2009 | GE Refrigerators
Where is the defrost timer located for my GE GS25jfmc fridge
Timer is usually located in rear of unit at bottom. Look for a plastic part with 3 or 4 wires sticking out. It has a one way screw driver slot for manually advancing. This part may be located in the cooler behind a plastic cover.
Nov 08, 2009 | Refrigerators
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
