Can the large cutting blade be replaced in this shredder?
    Top Expert:
  • Office Equip... Master
  • 8,304 Answers
You could try looking on ebay i seen some on there the other day.
just put into ebay the info of your shredder and see if it finds any.
Posted on Dec 17, 2016
  • Donna Meyer
    Donna Meyer Dec 17, 2016
    THANK YOU
  • NOEL
    NOEL Dec 17, 2016
    you are welcome
Our C220c shredder does not shred, motor turns and blades turn but i think the blades are blunt. Can you get new ones or have the old blades sharpened?
There are 2 shafts that have the cutting blades on them and they both should turn. I have replaced many gears on this model and suspect that a gear is broken. Fellowes does not have many parts this model anymore. I would call a local shredder repair service or you can call Fellowes at 800-955-0959.
Sep 11, 2013 | Fellowes 220C-2 Shredder
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
Paper has wrapped around the cutting blades and is packed in tight. How do I clean this?
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse. Pull on the jammed pieces as the shredder shifts between directions.
    • 3 Run the shredder in reverse continuously once the paper jam is cleared. Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
Knocking noise when shredding paper
Cross-cut shredders require monthly oiling of the cutting cylinders to maintain proper operation. Failure to oil the blades regularly could result in excessive noise during operation.
Oiling Your Shredder's Cutting Blades:
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three times.
I hope the above helps....
Good luck.
Apr 13, 2011 | Fellowes DM8C Cross-Cut Shredder
How mcuh would it cost to replace the blades on a
Hi Charlene,
Replacing the blades is not the problem, trying to find them is.
Sorry, but you need to buy a new shredder.
Nov 27, 2009 | Fellowes Manufacturing 120C (Confetti-Cut)...
Od700c shredder: motor spinds, blades don't move
Inside the motor assembly there are a series of nylon cogs , a large one of which interacts with a metal one.  This is the most likely place you have one or two teeth missing from the large nylon cog that drives the shredder blades.
Sep 22, 2009 | Fellowes OD700C Shredder
Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Jul 05, 2009 | Fellowes 3011001 Shredder
No longer cuts through paper
This is the problem I have the paper no longer cuts all the way. Some parts just seem marked with out cutting what do I do?
Apr 17, 2009 | Techko 6-Sheet Straight-Cut Shredder
Cutting problem
Pour some shredder oil onto a sheet of paper and shred the sheet of paper...do this a few times to get the oil down into the cutting blades.
Mar 03, 2009 | Royal 1280MX Shredder
62 people viewed this question
k24674
jasbo
jasbo
