Question about Xerox 6R1238 6204 Wide Format Printer Toner
116-312 error code in 6204 - Xerox 6R1238 6204 Wide Format Printer Toner
I am getting an error message "external device error" chain link 116-311 for xerox 6204 machine
"external device error" chain link 116-311 for xerox 6204 machine how to solve the proplem
Dec 09, 2013 | Xerox Office Equipment & Supplies
Error Message PXE-MOF: Exiting Intel PXE ROM. what does this mean?
That means your hard disk is not being detected. PXE is a network boot, which is typically used in business environments. Check your BIOS settings and ensure your hard disk is being detected. If it is, make sure your boot order is set correctly. Network boot (PXE) should be set to the last item in the sequence. If the hard disk is properly being detected and an OS is present, you should never see PXE.
If your hard disk is not showing up, power your PC down (unplug the power) and check the cables to make sure they are seated.
Mar 17, 2013 | Acer TravelMate 5730-6204 Notebook
Windows vista not bootable. where can i find the bootable disk for travel mate 5730 laptop
Try holding F8 when booting, choose 'repair my computer' and then 'restore my computer to factory setting'
Jul 01, 2010 | Acer TravelMate 5730-6204 Notebook
I lost my bios pasword and my hdd pasword from my tm 5730
The only way to reset this is to open the laptop up, remove the motherboard battery for 30secs and reboot before putting it back in.
Error code 1-2036 on Kodak ESP3 printer
Perhaps this will help, universal error codes for the Kodak 5100 thru ESP 9 inkjet printers:
RME: Kodak
STATUS_OK_ALL = 0,
STATUS_OK_MANUAL_DUPLEX_STARTED = 97,
STATUS_OK_MEDIA_DETECT_STARTED,
STATUS_OK_FORM_FEED_STARTED,
* Informational (0100-0999):
* Busy (1000-1999):
STATUS_BUSY_SYSTEM_BUSY = 1999,
* Warning (2000-2999):
STATUS_WARNING_IMAGE_TOO_LONG = 2998,
STATUS_WARNING_IMAGE_TOO_WIDE,
* Asynchronous Ok (3000-3099):
STATUS_OK_MANUAL_DUPLEX_COMPLETE = 3000,
STATUS_OK_PAGE_EJECTED,
* Asynchronous Warning (3100-3199):
STATUS_WARNING_BLACK_INK_LOW = 3101,
STATUS_WARNING_COLOR_INK_LOW = 3102,
STATUS_INK_TANK_INVALID_MANUFACTURER_COLOR = 3103,
STATUS_INK_TANK_INVALID_MANUFACTURER_BLACK = 3104,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_COLOR = 3105,
STATUS_INK_TANK_VERSION_EXCEEDS_FW_VERSION_BLACK = 3106,
STATUS_MEDIA_VERSION_EXCEEDS_FW_VERSION = 3107,
STATUS_INK_OVERFLOW_EXCEEDS_CAPACITY = 3108, // Will be deprecated
STATUS_WARNING_BLACK_AND_COLOR_INK_LOW = 3109,
STATUS_WARNING_PROOF_SHEET_WRONG_MEDIA_SIZE = 3110,
STATUS_WARNING_PROOF_SHEET_WRONG_SESSION_NUMBER = 3111,
STATUS_WARNING_PROOF_SHEET_NO_IMAGES_SELECTED = 3112,
STATUS_WARNING_PROOF_SHEET_READ_ERROR = 3113,
STATUS_WARNING_MORE_THAN_1000_IMAGES = 3114,
STATUS_WARNING_INVALID_DPOF_FILE = 3115,
STATUS_WARNING_NO_IMAGES_FOUND = 3116,
STATUS_WARNING_SCAN_TO_OPERATION_FAILED = 3117,
STATUS_WARNING_BLUETOOTH_CONNECTION_DROPPED = 3118,
STATUS_WARNING_UNSUPPORTED_USB_DEVICES = 3120,
STATUS_WARNING_OVERCURRENT_USB_DEVICE = 3121,
* Asynchronous and Synchronous Error (3200-3499):
* Job Recoverable. No User Interaction.
// STATUS_PRINTER_BUSY = 3201, // not used. duplicated number
STATUS_INK_TANK_REPLACEMENT_IN_PROGRESS = 3207,
STATUS_PRINTHEAD_UNCAPPED_TIMEOUT = 3208,
* Asynchronous and Synchronous Error (3500-3599):
* Job Recoverable. User Interaction Required
STATUS_ERROR_UNIT_OPENED_WHEN_IDLE = 3501,
STATUS_ERROR_MAIN_PAPER_TRAY_EMPTY = 3502,
STATUS_ERROR_PHOTO_PAPER_TRAY_EMPTY = 3503,
STATUS_ERROR_PAPER_JAM_DURING_PICK = 3504,
STATUS_ERROR_NON_PLAIN_DETECTED_DUPLEX = 3505,
STATUS_ERROR_MEDIA_SIZE_MISMATCH = 3506,
STATUS_ERROR_INK_OUT_BLACK = 3507,
STATUS_ERROR_INK_OUT_COLOR = 3508,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_COLOR = 3509,
STATUS_ERROR_INK_TANK_INSERTED_INCORRECTLY_BLACK = 3510,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_COLOR = 3511,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK = 3512,
STATUS_ERROR_PRINTHEAD_NOT_INSTALLED = 3513,
STATUS_ERROR_BACK_COVER_REMOVED_WHEN_IDLE = 3514,
STATUS_ERROR_CARRIER_STALL_DURING_PICK = 3515,
STATUS_ERROR_MEDIA_LOADED_UPSIDE_DOWN = 3516,
STATUS_ERROR_INK_OUT_BLACK_AND_COLOR = 3517,
STATUS_ERROR_INK_TANK_NOT_INSTALLED_BLACK_AND_COLOR = 3518,
STATUS_ERROR_PHOTO_TRAY_ENGAGED = 3519,
STATUS_ERROR_FAIL_TO_DETECT_PAPER_EDGE = 3520,
STATUS_ERROR_VOLTAGE_TO_PRINTHEAD_NOT_CALIBRATED = 3521, // Should only be used at the factory
* Scanner (6000-6299):
SCANNER_ERROR_ADF_PAPER_OUT = 6101,
SCANNER_ERROR_ADF_PAPER_JAM = 6102,
SCANNER_ERROR_MOTOR_LOCK = 6201,
SCANNER_ERROR_MOTOR_MOVE_FAILED = 6202,
SCANNER_ERROR_HOME_NOT_DETECTED = 6203,
SCANNER_ERROR_CALIBRATE_FAILED = 6204,
SCANNER_ERROR_ADF_SENSOR_FAILURE = 6205,
/* Internal used errors. to be removed */
STATUS_ERROR_PAPER_JAM = 3201,
STATUS_ERROR_CARRIER_STALL = 3202,
May 12, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Xerox 6204 error 071-103
The cutter assy has a disk with hole in it to tell the circuit board how fast it is turning and where it is in respect to the home position. It may be that this disk or the sensor that looks through it has a lot of paper dust on it and not able to read correctly. It may me the the cutter itself is sticking and needs a little cleaning and oiling.
Jan 23, 2008 | Office Equipment & Supplies
Xerox 6R1238 6204 Wide Format Printer Toner Logo
41 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
