Question about Sony Computers & Internet
I have a 19.5v sony AC adapter that wont charge my laptop and it keeps beeping when its plugged in how do i fix this?
    Top Expert:
  • Sony Master
  • 8,248 Answers
Is the ac adapter the one that come with this laptop?
it might be the ac adapter has got a fault with it.
take the battery out of the laptop and then plug your ac adapter in and see if you can switch your laptop on.
if it does come on with the battery out then it might be the battery thats at fault.
Posted on Dec 17, 2016
  • 1250 Answers
SOURCE: The AC Adapter makes a beeping noise and doesn't charge the batt.
I would verify that the battery will take a charge. If the battery is bad, the charger will tell you that it is not charged. It will not tell you why, just that it is not charged. If not plugged into the computor,again, battery is not charged. Hence, the beep.
Good Luck and hope this helps.
Posted on Mar 15, 2009
SOURCE: Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Posted on Aug 25, 2009
  • 1481 Answers
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
Posted on Dec 29, 2009
SOURCE: Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Posted on Jan 09, 2010
SOURCE: LIGHT COMES ON AC ADAPTER BUT GOES OFF WHEN PLUGGED INTO NOTEBOOK
This is possibly an internal power Supply fault. take the battery out, plug in the adapter, IF the unit works now, you have A: A battery problem, or B: a charging circuit problem. If the unit still fails to work, the power supply in the PC has faulted. You need to get a "Quote: for a repair.
Posted on Mar 17, 2010
Testimonial: "Thanks! I removed the battery and it started right up! So would a new battery fix it? The only thing is the touch pad is not working. We plugged in a "
My hp ac adapter KEEPS FREEKIN BEEPING
Hello, NO it isn't going to explode, you need to replace the battery or the power cord it isnt charging or being charged.
Jan 16, 2013 | HP Original 90w Ppp012d-s 519330-003 Ac...
Asus ASUS A53U-ES21 wont power on
In order for the AC adapter to work the battery must be in good condition, why? Because the system runs of battery the AC adapter just keeps the battery charged up while in use, if the battery is open or defective the computer will not run on just the AC adapter.
Jul 12, 2012 | ASUS Computers & Internet
Is there a software that is associated with my sonny battery that will make it charge again
If you plug in your AC adapter to your laptop to charge the battery and get the "plugged in, not charging" message then try the following solution:
  • Disconnect AC adapter
  • Shutdown laptop
  • Remove laptop battery
  • Connect AC adapter
  • Power on laptop
  • Click the Startup Menu
  • Type Device and select Device Manager
  • Under the Batteries category, right-click Microsoft ACPI Compliant Control Method Battery and select Uninstall.
  • Shutdown laptop
  • Insert laptop battery
  • Power on laptop
    If you follow these steps and find that your laptop still does not charge then consider replacing the laptop battery itself.
    Hope to have been of assistance,
    Thanks.
  • Sep 14, 2011 | Sony VAIO PCG-K23 Notebook
    I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
    1. Unplug AC adapter. Shutdown
    2. Remove battery, Connect AC Adapter
    3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
    4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
    5. Power up -
    Now Plugged in and Charging.
    Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
    My lonovo laptop won't charge. how do i fix it?
    if ti works with the adapter plugged but the battery do not charge to work without adapter ..than the battery is dead and you need to replace it ..If it do not work without battery and just with the adapter ..it means tha adapter has an issue and try to check the plug ..the cable and the adapter itself..before buying another verify at the store with the laptop to see if the adapter is to blame ...and not the plug into the computer ..so you do not end up with 2 working adapters ..and still no charge ...If it is the plug itself ..then you have to change it ...you can get a spare part on the ebay..or just go to a repair shop ..cause they are pretty universal ...
    May 12, 2010 | Lenovo Ideapad U350 Laptop Notebook
    I got a new ac adapter but it wont turn on
    If the laptop battery is completely flat it may take up to an hour to get up enough charge to allow the machine to work
    Plug it in and leave it for a few hours
    Feb 04, 2010 | HP Pavilion ZD8215us...
    I HAVE A ASPIRE 5520 IT WONT START THE FAN STARTS AND THE DVD BUT IT JUST KEEPS ON LOPPING
    I had the same problem but what you can do is...
    Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
    If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
    1. Unplug the ac adapter. Keep ac adapter unplugged.
    2. Remove the battery and keep the battery unplugged.
    3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
    4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
    5. Normally power on the notebook.
    6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
    7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
      If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
    8. If its not the batery or AC adapter you might have to send it to Texas, just go to www.Acer.com
    Jun 14, 2009 | Acer Aspire One PC Notebook
    Can some one tell me how to fix my ac adapter VGPAC19V19
    You should contact your services center, because opening charger without enough knowledge is not an suggestion
    May 08, 2009 | Dell HQRP Replacement Laptop AC Adapter
    Mar 15, 2009 | Toshiba Portege R100 Notebook
    Computers & Internet Logo
    65 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
