How do I get the DVD icon to show up in my input selection?
Model TLCD-32HD not showing signal I guess the tv icon inactive i will send tv picture noe
Check its input selection. If it has been selected either to AV or HDMI; the tuner icon will get deactivated. Select the input to tuner {TV}. It will make it right.
Jul 20, 2016 | Televison & Video
Fault A2
Are you SURE it's a fault code, and not the selected AV input? (A1, A2 or A3?
Press the Input Select button on the remote to cycle between AV inputs and Freeview channels
Jun 22, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Do you need the red yellow white blue and green to have it show on the power its on but it wont show up on the t.v. so if you know whats rong on it holler at me
You need tyo select the input on your tv that matches how you have the dvd player hooked up if you are using hdmi select hdmi, if you are using the red yellow green blue and white cords these are called component video cables so look for something along those lines on your input selection screen
Apr 02, 2011 | Cyberhome CH-DVD 300 DVD Player
What channel is the s vidio channel ?
s video is the channel you see when you select input on your tv and it shows the device you hooked up to the svideo port on your tv..its different for every tv. ex: You plug in you dvd player to svidoe on your tv..select your input till you see what the dvd player is playing.
Jun 15, 2010 | Toshiba 27A41 27" TV
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
My Magnavox TV #19PSC5 0121 won't show me the A/V signal from my DVD. I don't have the original remote and there is nothing on the front panel or on the Menu that will allow me to get to the ''Input'' so I...
1.Check the input setting of your TV.Try to find the input setting of your TV go to menu and select the selected input you are using, its either rca input 1,2,3 or vga input.Try to read the label of your input if its input 1,2 or 3 then select the setting in input set-up.
2.Configuring the appropriate setting and still the problem did not solve.Try to substitute your DVD with another functional DVD.But before also replace your RCA cord to take away the probability of defective cord.After replacing another DVD and the problem is solve, your DVD setting must be check if its in pal or NTSC setting.Try to press N/P button on your remote.
3.If the following procedure does not work.Your unit needs to be check by an expert.This could be a service mode repair or internal components repair.
Jul 19, 2009 | Televison & Video
Technically challenged...need DVD to show on TV screen
hey 1st of all you gotta make sure that your son made tha right connections with the av cable (this is the cable with three different coloured pins) from your DVD to your tv. if this doesnt solve your problem then make sure you are using the correct av channel on your tv set that will allow you 2 play your DVD player because sometimes you cant play your DVD on thhe same av cannel you watch normal tv
Jan 01, 2009 | Pioneer DVR-520H DVD Recorder
Setup
You need to select the appropriate video input on the television. If you have done this, you need to check your connections. Most likely you connected it via the red white and yellow cables. Therefore, find the remote for your TV (the one that actually shipped with your TV - not the one you use for cable or satellite) and look for a button labelled something like:
TV Video, Video Select, A/V, AV Select, Input, Input Select, Device, Source, Auxiliary, Line, etc. When you press this - your television should change to what's called an input mode. One of these input modes will likely give you a picture from the recorder. If not, call Panasonic.
Apr 02, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
