Question about Toshiba Office Equipment & Supplies
Find waste toner box on Toshiba Studio 305CP - Toshiba Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: Waste Tone Box
Your machine catch's excess toner and puts it in a container and needs you to replace/empty it soon or it will have to stop work, sorta like needs just a dash of attention for all its effort.
The bottle at a guess for this model will be apparent when opening front door, instruction are probally on the inside of door but it is just a container full of black messy stuff that needs to be emptyied and replaced....hang on I'll google it....looks like you need to buy a new box and that will have instructions even.
Some links for your product toner box
http://www.precisionroller.com/catalog_display.php?mfname=konica_minolta_bizhub_c450p_waste_toner_container_details&m=297&d=7597&c=40&i=31526
http://www.tonermax.com/KONICA-MINOLTA-BIZHUB-C450-WASTE-TONER-BOTTLE/i/24194
Posted on Oct 31, 2007
leroyal
  • 2120 Answers
SOURCE: Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Posted on Feb 05, 2009
  • 13 Answers
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Posted on Jul 20, 2009
Shah_Sheh
  • 81 Answers
SOURCE: HOW DO I CHANGE TONER WASTE BOX AND WHERE IS IT ON lexmarkc534
I presume from your question you have a message that has popped up 'Replace the Waste Toner bottle'. This is a consumable item and will need to be replaced every 30000 pages. Emptying the old one is not recomeded as the toner is very fine, very messy, very hard to get spills out of clothing and so you will need to purchase a replacement (instalation instructions provided)
Posted on Sep 09, 2009
  • 19 Answers
SOURCE: What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Posted on Oct 11, 2009
Testimonial: "I had no clue what a waste toner box is. Your response helped me. Thank you."
How developer material fall in wastage box to repair it?
Is normal for excessive toner/developer go inside waste toner box...Once the waste toner box full, u need to dispose it and make sure the sensor detection surface on the box is not dirty...
Mar 13, 2015 | Toshiba E-studio 452 Digital Copier...
Where is the waste toner cartridge located on toshiba 3540c
Waste toner box located beside the drawers. Open the cover and u can take out the waste toner box.
Aug 25, 2014 | Toshiba e-Studio 3540C Multifunction Color...
Toshiba e-studio 5520c cd81 keeps coming .even after cleaning the toner disposal bottle
This error code is not for the waste toner box. The problem is the transfer waste motor (right side duplex door of machine). Probably clogged auger stalling motor which needs to be vacummed out.
Aug 03, 2014 | Toshiba e-studio 5520c Digital Copier
We replace the used toner bottle but the copier (Toshiba Studio 351c) keeps giving us the message to dispose of the used toner container
There is a sensor just behind the waste toner box that sends beam through the water toner box to see if reaches the other side. If it does not, then the sensor thinks that the box is full. So you need to clean the waste toner box with some liquid cleaner so that it looks white from outside. Once the box is dry, try again. This should work now. Otherwise, there is problem with the sensor.
Sep 23, 2010 | Toshiba e-Studio 350 Copier
Hi, My Toshiba E-Studio 3511 color copier has a error message of 'dispose of used toner.' Even if I followed the direction, the error message is still there and the copier can't work. Would you help me...
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Aug 11, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba 3530c estudio waste toner error message.
Your waste toner box is located inside the front cover on the far left side of the copier. There is a plastic cover that is just clipped in (no screws) and just pops off, the waste toner box just slides out from there.
Jul 06, 2010 | Toshiba E-Studio 3511 Color Copier
We get Dispose of used toner even though we empty the toner bag. any ideas
Mar 11, 2010 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
I have a toshiba e-studio 2500 and i keep getting the empty used toner msg. i have replaced the tonerbag
Use your hand and tap the tube going to the used toner bag. Does it sound full? sometimes the toner will clog the tube and back up. You need to knock it loose so that the waste toner will empty. Also check the waste toner bag switch, it may have gotten knocked out of position when removing it the first time. If so just reposition and / or reshape.
Dec 23, 2008 | Toshiba e-Studio 350 Copier
64 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
