Question about Bissell Vacuums
I just change the flow indicator on my Bissell Green Machine and seen that the the two hose that attach are dry rotted. Can these be replaced?
    Master:
  • 234 Answers
Anything can be replaced on it. Have patience and the new part ready.
Posted on Dec 17, 2016
Testimonial: "I have no idea what that answer means."
  • 1 more comment
  • Merle Evans
    Merle Evans Dec 18, 2016
    It means, Yes, you can replace the two dry rotted hoses. Your question was, "...the two hose that attach are dry rotted. Can these be replaced?" The answer is, "YES".
  • Daria Morgendorffer
    Daria Morgendorffer May 16, 2017
    I love my dix pix. Tux paint in my trousers. ANACONDA *waves will wrights sim game*
    Are you a man or a tin can, David?
My machine will spray from the hose attachment, but not when I am doing floors.
Check Flow Indicator Filter under the Flow Indicator. Turn Indicator cap counter-clockwise, remove rotor. Filter is under rotor and pulls out. Clean filter. Additionally, check LINT FILTER in the clean water tank cap. Check you User's Guide if you have more questions or call the Bissell Consumer Care at 1-800-237-7691 The other thing you can do in this case is reseat the tank. It may be blocking the housing connection but the sprayer connection is smaller and open. Cleaning the filters after each use though is recommended.
Dec 06, 2015 | Bissell ProHeat Pet Upright Deep Cleaner,...
Why can't I use the attachments to clean my couch?
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
Nov 30, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Big Green barely sprays any water.
Check you User Guide and see where the filters are. They usually have have a filter under the flow indicator. Turn the Flow Indicator cap counter-clockwise to remove it. Lift out the rotor and the filter is under it. Remove it and clean. Reinstall in reverse order. I don't know anything about the specific machine you have but I know they have a flow indicator from other comments I've read so it's worth the try.. Hope that Helps.
Jul 22, 2015 | Bissell 86T3 Big Green Clean Machine
Bissell big green clean machine extention hose not spraying
Hey, sorry you're having difficulty with the spray on the hose.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=23646&cid=ccsocial
Feb 28, 2013 | Bissell Big Green Deep Cleaning Machine...
Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Jun 28, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
No water from my Bissell
I AM BISSELL WARRENTY DEALER, AND MOST COMMON PROBLEM WITH THESE UNITS ARE CLOGGS IN THE LINES AFTER THE HEATER OR IN THE HEATER THEM SELFS VERY DIFFICULT TO GET INTO. THE PUMP IS A DIRECT DRIVE WITH NO BELT AND I HAVE NEVER HAD TO REPLACE ONE NOT TO SAY ITS NOT THE PROBLEM BUT UNLIKELY IF AT ALL POSSIBLE TRY TO GET SOME FLOW AND TRY RUNNING SOME SORT OF LIME AWAY CLEANER INTO SYSTEM AND LET SIT THIS WILL HELP PREVENT CLOGGS AND POSSIBLY CLEAR CLOG OTHER WISE YOU WILL HAVE TO DISSASSEMBLY MACHINE AND CLEAR HEATER AND LINES MANUALLY. IF YOU GET WATER TO ATTACHMENT HOSE BUT NOT NOZZLE YOU MAY CHECK THE RED TIPS FOR CLOGGS. THESE CAN BE REMOVED WITH OUT TAKING THE MACHINE APART.
Mar 30, 2008 | Bissell 9400 ProHeat Upright Wet/Dry...
Hoses to and from pump
I have a Bissell Model 1699 when I removed the pump to this unit to go buy a replacement I wrote discriptions of where the disconnected hoses went. Apparently my descriptions were poor. Now after switching the hoses all around I am not sure where they go. I cant get the thing the thing to go backt together because apparentely the hoses arent routed properly How can I find out where they are supposed to be connected and how they are routed.
Sep 26, 2006 | Bissell 7901-1 ProHeat Scotchgard Upright...
Vacuums Logo
67 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
