Question about Kenmore Washing Machines
Kenmore 106.53662300 diagnostic test mode - Kenmore Washing Machines
  • Bobby G Hatfield JR Dec 17, 2016
    How do I go in the test mode and what are the codes
  • Kenmore Master
  • 5,323 Answers
TURN THE DIAL 1 WHOLE TURN THEN TURN IT 1 CLICK LEFT AND 3 CLICKS RIGHT THEN 1 CLICK LEFT , THEN 1 CLICK RIGHT IT SHOULD THEN GO INTO DIAGNOSTIC MODE AS FOR THE CODES U SHOULD HAVE A SCHEMATIC TO SHOW THEM
Kenmore Elite HE4T washing machine diagnostic test not completing - getting stuck on C05
http://www.managemylife.com/images/6975/original/346.jpg?1303498921
According to this it could be either the Computer (don't think so but don't rule it out just yet.), the fill valve, or the heater. Appliance Repair Forums
This link will help you test the fill valves.
This will link you to a service manual for the HE3T washer which is very similar to yours and the diagnostics and tests will be the same. https://www.ifixit.com/Document/1074/.pdf
Jan 20, 2017 | Kenmore Washing Machines
Kenmore model 110.251102310 top loading washer has problems with wash cycles.
check the mode shifter? can u run an error code diagnostic as the shifter cannot be meter tested to see if defective? other wise u may have a bad timer with burnt point contacts. or a bad harness and or motor control board. this is why you really need to put it in diagnostic mode
Dec 31, 2016 | Kenmore Washing Machines
Kenmore washer model 11044722401 how to manually advance the cycles? Sears technician showed me how a few years ago-- so I know it can be done. It is a technician diagnostic test/ function.
With the washer off, unplug it and plug it back in the lights should blink twice. Then press the wash temp and water level keypads at the same time. The water level should stay on but all others should stay off. If this happens the washer is in diagnostic test mode. Hope this helps
Nov 04, 2016 | Kenmore Washing Machines
How do you start diagnostic on kenmore elite smartheat quiet pak 9 HE4 dryer?
Hope this helps
By Manage My LifeDecember 30th, 2011
Kenmore Elite Dryer HE4 Quietpak 9 Model 110.85091400 has 4 dim lights showing on the console display but won't start or respond
Our dryer just quit working yesterday and I am puzzled. There are four lights very dimly lit on the display. They are the Casual button, the Timed Dry button and two of the segments in the oval time window. I have found the information online about how to test with a multimeter to try and figure out which board is bad. Unfortunately all these instructions require you to have the dryer in the diagnostic mode by pressing the More Time/Less Time/More Time/Less Time in less than 5 seconds. When we do this it does nothing and will not enter the diagnostic mode. When I am testing with the multimeter on the P3/P4 connections I am not getting any readings of voltage at all. Is this because of not being able to get into the diagnostic mode? Should I still be getting readings? I know we have power to the dryer because the light still turns on when you open the door. The cost of buying both the main control board and the front console are prohibitive for us and I would like to only buy the one that is bad. I have also tried the testing with the multimeter on the front console buttons and also get no readings of ohms at all. We have a very busy household with lots of kids and this dryer is very essential to us so the quicker we can get this fixed the better. Thank you in advance for your help.
Jul 03, 2015 | Kenmore Dryers
Kenmore dishwasher blinking E2F2
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Then you have to wait 2 minutes while your Kenmore dishwasher runs its diagnostic test.
Then press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop any lights from blinking.
Jan 29, 2015 | Kenmore Dishwashers
Kenmore High Capacity Dryer won't go into diagnostic mode
faulty touch panel key pads are the most likely suspect. Prior to diagnostic you should be able to enter the fault code memory to reference what fault codes are stored in the main board. Pleazer Appliance...
Apr 23, 2014 | Kenmore Dryers
Cannot reset error codes on front losd washer
If these tests do not reset it is possible that the program controller processor is a suspect as there can be errors in the memory.
Dec 31, 2012 | Kenmore HE2 Plus Front Load Washer
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Kenmore HE4 Dryer leaves clothes wet
From the techincal document found in the dryer bottom panel
TEST #4a Dryness Level Adjust
NOTE: If the customer is complaining about the clothes being damp and the moisture sensor passes TEST #4 "Moisture Sensor Test- step 3, then the total dry time can be lengthened by changing from a "Lo" for short auto cycle to "Hi" for longer auto cycle.
1. Activate the Diagnostic Test Mode. Press the following button sequence: MORE TIME ~ LESS TIME -+ MORE TIME --+ LESS TIME - all within 5 seconds
1. In diagnostic test mode, press and hold the Auto Dry Level key for 5 seconds. The dryer will beep and the current auto cycle mode will be seen on the display. The factory default setting is "Lo".
1. To select a different auto cycle mode, press the Auto Dry Level key again. The dryer display will flash and show either "Hi" or "Lo"
1. With the display flashing the selected auto cycle mode press the Start key to save the setting and exit diagnostics (the Start key in this mode does not start a drying cycle). The result will be stored in EEPROM of the control board.
SO EASY JUST TOOK ME 3 YEARS TO FIND IT
Ross
Feb 28, 2009 | Kenmore Elite HE4 Electric Dryer
No spin
Cowboy, make sure the lid switch is operational. If it is and you can get it to spin in the test mode but not in the regular cycle, sounds like a control board issue to me. Catriver..post back.
Sep 25, 2006 | Kenmore 42182 Top Load Washer
Washing Machines Logo
55 people viewed this question
Sal De
fordexpert
Robert Rankin
