Question about GPX MW3837 MP3 Player
It won't turn on
When i plug it to the charger it will display that its charging but when i unplug it then it won't turn on
  • 6 more comments
  • 195948 Dec 06, 2007
    my media player says that the songs are on my mp3 playerMW3837 1GB,but I can't figure out how to get the music to play. Can you help?
  • shawn  pengelley
    shawn pengelley Dec 09, 2007
    i got my mp3 player when i turn it on it says gpx then it turn off .
  • Anonymous Dec 14, 2007
    When I turn on the GPX MW3837 it says HOLD, then BYE. Help
  • Anonymous Dec 26, 2007
    when i turn mine it it says "hold" and then it says "bye"
  • Anonymous Dec 30, 2007
    Same problem
  • Sarah Kehoe Jan 05, 2008
    Was working fine and then 5 minutes later it wouldn't turn on. It still charges and takes songs no problem but won't turn on.
  • Jim Hardesty Feb 02, 2008
    same thing for my player
  • 3Nagurski Feb 07, 2008
    My device will recognize when it is connected to the USB, however, it will NOT turn on. It was operating for about (4) months. The problem began about (2) weeks ago and this sympton progressed to the point that it just does not turn on.
You have your mp3 on hold at the top switch the hook to unlock that should work
Posted on Apr 07, 2009
Mine worked the night i got it charged it and put the music on it and waited till the next day to unhook it from my laptop. did the logical thing and fliped the switch up to on and pushed play it said hold and good bye! then the damn thing locked up and would not turn on try reseting it and holding in differn't buttons nothing. so i took mine apart and crossed the neg. and possitive from the battery and then it worked hope this helps people. and make sure not to turn on leave off and just hold in the play buttion.
Posted on Mar 28, 2009
Don't flip the switch to on. Just leave it in the down position and hold the middle button and it will turn on.
Posted on Jan 01, 2008
Not charging
The chances are that the battery has failed. The age of the device would indicate that the battery is probably NiCd - these batteries have a memory effect that means after a while the battery thinks that "fully Discharged" would be the state that is the most usual for the charger to be used most often. You will need to open the device to get the battery out to find the part number. You will then be able to order on from an online retailer.
Jul 11, 2013 | Aluratek APMP101F Cinepal HD Media Player...
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
My Samsung Galaxy Precedent won't turn on or charge anymore...I plugged it into the charger one day and it displayed
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue.
Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop.
Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter
If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery.
hope this helps
Aug 29, 2012 | Computers & Internet
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
Just replaced batteries and unit is operating good since i installed the battteries and i try to put on charger it says it is in the charge inhibit mode that is according to the flashing lights what does...
All that eans is that when you are charging the batteries you are unable to drive the chair. Its a safety feature to ensure that you won't accidently make the chair move with the charger plugged in. Just plug the charger into the charger port turn off the chair and then plug the charger into the wall charge overnight and in the morning unplug the charger from the wall and then from the joystick. Always have the charger off when plugging ang unplugging from the chair. With the M41 charger get a power strip with an on/off switch plug the charger into the strip and use the on/off switch to turn the charger on and off before you plug it into the chair Hope this helps you
Jun 20, 2011 | Electric Mobility Invacare Pronto M41...
E260 Wont Turn On
on the desktop click right button and click go to the apperance below the windows and buttons chane it as windowsxp style.
Jun 14, 2008 | SanDisk Sansa e260 MP3 Player
108 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
