Question about Water Water Heaters
We have MAREY ECO270 electric water heater . It worked 2 hrs ago now it is not working how do we reset it
Accurate Joe
  • 61 Answers
SOURCE: We just bought a Whirlpool
You need to be skilled to work on live electrical appliances. If you are I can continue. If not you need to call a electrician or a plumber.
Make sure both thermostats are set at the same temperature. Let me know what you find.
Posted on Nov 30, 2008
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Posted on Oct 11, 2009
  • 409 Answers
SOURCE: electric hot water heater gives lukewarm water
replace upper thermostat and hi limit switch. These are usualy made in one piece. On a two element heater, only one element comes on at a time
Posted on Mar 10, 2010
  • 6674 Answers
SOURCE: i have a atwood hot water heater GC6AA-10E its o...
Does yours have the little cut-out diode looking thing in the plastic jacket installed between power wire and thermostat? If yes, remove it from the circuit and connect female spade of wire, to male spade of thermostat,(just removing it to by-pass it) and try it now. Let me know what happens.
Posted on May 25, 2010
  • 528 Answers
SOURCE: constant water leak from the
That is the temperature pressure relive valve (TPV) . It is either foiled with some thing or going off because of a pressure or temperature problem. If it is leaking continuously it is foiled and needs cleaning. If I where there I would replace it with new.
Posted on Feb 08, 2011
We need to find out what is wrong with our hot water heater. It is a Marey 180. It quits heating water. You can cut it off for several hrs then cut it back on and it will heat again
Hello, busby_betty -
Clarification: You have a Marey ECO180 Electric Tankless Water Heater. If so, I checked the owner's manual, here:
in case your problem was mentioned in the Troubleshooting section. It wasn't.
Therefore, before you call for a repair technician to come and evaluate your water heater, I suggest you telephone the Marey Customer Service number: 855-627-3955 to find if the Customer Service representative has any ideas on what needs fixing. Or, you can send an email: .
When you contact Marey Customer Service, ask about the nearest authorized Marey water heater service business, so you may call and make an appointment for a service technician to come to your home and check what is wrong and repair it.
If you were hoping an authorized Marey water heater repair person was sitting on waiting for questions about Marey water heaters, that isn't the case.
Note: It may be a problem with the water heater thermostat or the or the heating sensor. Also, check the information here:
(Copy the URL and paste it into the address box of your browser, if it isn't hightlighted as a link.)
The real problem may be with the electrical wiring and circuit to which the water heater is connected.
Jan 04, 2018 | Water Water Heaters
What are the pros of Marey Power Gas Tank less Water Heater?
The pros of the Marey Power Gas Tank less Water Heater are as follows:
1. Available in propane and natural gas
2. DIY installation process optional
3. Very reasonably priced Does not use electricity but does require a 2 D-Cell battery
4. Only uses gas, when water is turned on (decreases natural gas wastes)
5. Equipped with easily adjustable gas and water knobs
6. Digital display makes it easy to read water temperature
7. Very compact design
8. Works great with low water pressure levels
You can have more information about it like how it works and installation process etc.
Jun 23, 2017 | Water Water Heaters
My water heater is a "Marey" propane and the water won't get hot and it keeps saying "E2" I lost my manual so I can't see what that means. Do you know?
An E2 code is often an indicator of an electrical problem inside the water heater. The most common problem is with the inlet water temperature sensor. Often a reset will fix the problem. To achieve the reset unplug the unit. Open the unit being careful of fragile electrical wires. Next remove the computer board and then disconnect each plug in wire and reseat them one at a time. Reassemble the unit and plug it in. It should be in working condition, without the E2 code.
Marey electric heater E2 error Marley Water Heaters
and also another idea here
found this helpful answer from plumber on JustAnswer com
and finally, how I found the answers.
E2 Google Search
Apr 26, 2017 | Water Water Heaters
Have 40 gallon electric hot water tank 10 gauge wire 20 amp double pole breaker federal pacific fuse box red black ground wire shows power on 2 hrs now not even Luke warm water what could be wrong
I'm an electrician and can help. Federal Pacific equipment is tough stuff. The company went out of business decades ago - due to faulty equipment they made. Aside from that..
There may be no power out of the breaker, bad connections between the breaker and water heater, bad thermostat, bad hi temp sensor, bad heating element and more. I wrote the article linked below - that will help you find and fix any of these problems and more - assuming you have the equipment and ability to work on electric water heaters. If not - call a licensed electrician.
How to Repair an Electric Water Heater
Jun 05, 2015 | Water Water Heaters
Ignition problem
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Nov 30, 2014 | Marey Heater Corp Marey Natural Gas 2.0...
Model 71-52DB 50 gal. water heater stopped heating
Press the reset button located on upper thermostat
Following link has troubleshoot for electric water heater
Jun 13, 2012 | Rheem Water Heaters
I have a Marey LPG tankless heater. The water temperature fluctuates. At my kitchen sink - warm water. In my bathroom shower lukewarm water. At my outdoor shower - nice hot water. How may I fix this...
Ok i intall tankless water heaters and sell them and repair them . The trouble your are hving is more than likely ,the mixing valve on your shower has a ajustment on it to prevent you from burning your self . that is the number one reason in showers when water never get to temp . What it is doing is addng cold water to your shower for you bummer . Take handle off and adjust water temp to your hottest setting . Some times you have to remove the low flow washer in shower head to get the right flow . also every time you start up your hot water it shouldbe set all the way ot other wise withe the battery 2 D models the unit will not sence flow and shut off the unit ,with some units it is a fine balancing act to get them adjusted right. If your buying a tankless water heater always buy a blower type unit that has a computer that runs it . You will be happy . If the Battery operated unit is for a cottage or a smallcabin then your just going to have to fix the pumbing to make it work right many of the safety features of the newer showers are not made to work well with tankless water heaters .
Apr 16, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Constant water leak from the valve that came in the MAREY water heater
Feb 08, 2011 | RTO Lp Gas Tankless Water Heater By Marey
Water Heaters Logo
93 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
