How do I make sure the tv is set up for 4K. The screen shows 720*420.
    Top Expert:
  • Televison & ... Master
  • 79,865 Answers
Unless the TV is a 4K it will not receive display in 4K, if the TV is 4K the media playing must be 4K or it will just be 720 or 1080.
Posted on Dec 17, 2016
I have a lg 4k tv . tv now is showing a green shade. Does this mean the screen got damage
Chances are the screen is ok, I would start by replacing the tcon board
Apr 01, 2018 | LG Televison & Video
What is the difference between UHD and 4K tv
Ultra HD and 4K difference...Technically, "Ultra High Definition" is actually a derivation of the 4K digital cinema standard. However while your local multiplex shows images in native 4096 x 2160 4K resolution, the new Ultra HD consumer format has a slightly lower resolution of 3840 X 2160...Hope this helps
Feb 06, 2018 | Televison & Video
Can i get amazon prime on my 4k tv
Of course. Prime is a service, but you mean Prime VIDEO and is available on every device.
You can only watch movies and TV shows in 4K Ultra HD from Amazon Video, Prime Video and Netflix if your Fire TV is connected to an HDMI port that supports HDCP 2.2. Any other devices that are part of your home theater setup (e.g. HDMI receivers, sound bars, etc.) need to support HDCP 2.2 as well.
Amazon.com Help: Watching Videos in 4K Ultra HD on Fire TV
https://www.amazon.com/gp/help/customer/display.html?nodeId=201859000
Can get amazon prime video on my 4k tv Google Search
Dec 31, 2017 | Amazon Computers & Internet
My amazon is not opening on the tv how can I fix it?
Basic Troubleshooting for Amazon Fire TV Try these common solutions to resolve issues like a blank screen, app errors, and problems with your display or audio.
Can't Connect to Wi-Fi for common solutions that may help.
Amazon Fire TV is Frozen, Blank, or Won't Power On for solutions.
Change Your 1-Click Settings. Manage Your Apps & Games.Contacting Your TV Manufacturer .
About 4K Ultra HD on Amazon Fire TV (2nd or 3rd Generation)Check the Video Resolution section under Display to make sure your connected TV meets HDCP 2.2 system requirements for watching video in 4K Ultra HD. For more information, go to Watching Video in 4K Ultra HD on Fire TV.
Calibrate Your Display
If part of your display is missing or cut off at the edges of your screen, your TV may be automatically scaling your picture.
You can use the Calibrate Display tool (Settings > Display & Sounds > Display > Calibrate Display) to adjust for this.
When you open the tool, you'll see four grey arrows pointing to the edges of your screen, which you can use as a guide when making your adjustments. Press the Up and Down keys on your Fire TV remote until the grey arrows are completely visible and touching the edges of your screen.
Contacting Your TV Manufacturer .Follow the on-screen instructions to make adjustments with your TV remote. You should still see the grey arrows from the Calibrate Display tool--make sure the tips of the arrows are completely visible and touching the edges of your screen.
Amazon Video Settings and Devices on the Amazon website.
Go to the Parental Controls section and enter a new 5-digit PIN under Amazon Video PIN. Then select Reset Your PIN.
MicroSD Storage for Amazon Fire TV (2nd Generation) .
USB Storage for Amazon Fire TV (1st Generation).If your storage device is compatible, try safely removing and then re-attaching it to your Amazon Fire TV:
  1. Select Settings > Device from the Fire TV menu, and then select your storage device.
  2. Select Eject.
  3. Wait for the on-screen confirmation before safely removing the device.
  4. Re-attach your storage device.
Oct 23, 2017 | Televison & Video
My hisense 43 4k tv keeps reverting to 480i from 4k when i check the output it says 4k not recognised but then i reset the tv and go back into the picture output menu it lets me put 4k back on my tv
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Dec 27, 2016 | Hisense Televison & Video
I want to upgrade to a 4k tv but my home theater does not support 4k. Can i run sound only thru it?
You can run the sound to the home theater system in many cases. It depends on the home theater system and the TV. If the home theater system has a digital audio input, it is easy to connect most 4K TVs. Connect the 4K source to the HDMI or Displayport connector on the TV. Check whether the digital audio uses an optical cable or a coaxial cable. Make sure that the TV has the matching output and get the correct cable. Set the TV to use external speakers (under the Audio part of the setup on most TVs) and turn off the internal speakers.
Very few 4K TVs have analog audio output. If your home theater system only has HDMI and analog (RCA red/white) audio inputs, you will need a digital to analog audio converter and both digital and analog audio cables. The converter will look like this: https://www.amazon.com/Gefen-Digital-Adapter-Converter-GTV-DIGAUD-2-AAUD/dp/B0013LWK3A .
I hope this helps. Please add a comment with the make and model of your home theater system if you need a more specific set of details about doing this.
Nov 20, 2016 | home Audio Players & Recorders
HOW DO I GET GIG1 OF MY JVC TV SCREEN
Is it a 4k set? If so, that is gig #1 input and you must use the remote to switch around the inputs to the one you have connected.
Feb 11, 2015 | JVC Televison & Video
Televison & Video Logo
93 people viewed this question
Top Televison & Video Experts
