Question about Refrigerators
I want to buy a 2 door fridge - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 51,218 Answers
This site is not e-bay or gumtree and is not a retail shop
go to you local retailer for white goods
Posted on Dec 17, 2016
My brand new fridge, one door style will not self close.
front raise 1 or 1 1/2 inches the side that is the door hinge side is 1/2 inch higher then the handle side. Tilt it on a slit angle towards the way that will force the door with the added weight of food on door shelf's. A perfectly level fridge is a useless fridge. If its only mission is for the doors to close from the maximum range its able to open.
Mar 16, 2017 | Refrigerators
Our Westinghouse RS662V fridge is tripping the power. Has done it twice in the past 2 months. Any suggestions?
This solution is one possible answer if it applies to you. My fridge did the same and i thought the fridge was dead. The fridges freezer compartment's door was being left open and the freezer would thaw out and produce lots of water which would accumulate in the rear in a container which overflowed causing the fridge to trip the power. Closing the door and drying the rear container solved the problem. There are other causes too but if this applies to you it is worth giving it a try. Good Luck!
Jul 20, 2014 | Westinghouse WHITE Fridge Freezer Bottom...
BCD232/HC2
Check the link:
http://lmgtfy.com/?q=WHERE+CAN+I+BUY+A+TRAY+THAT+HANGS+AT+THE+BOTTOM+OF+THE+FRIDGE+DOOR+IM+IN+JOBURG
Jul 14, 2014 | Televison & Video
Should I buy a Samsung 26 cu. ft. french door fridge with ice maker on top?
hey there, it depends on your budget and what fits in your kitchen, my self have a
Samsung RFG23UERS1 fridge and i am very happy with that one, so like i said its up to your budget and if it fits
Nov 25, 2013 | Refrigerators
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
We have this model westinghouse fridge which currently opens to the right but are moving house and the fridge needs to open to the left. I can see holes on the left side with white plugs in them so it...
Yes depending on age. once changed doors never seal properly. because cabinet warps and seals flatten on one side. suggest to sell and buy another. you will never be happy if converted.
Aug 30, 2010 | Refrigerators
Have a magic chef refridgerator and the water is leaking on the items below. Fan is working fine in the freezer compartment. There is icicles on the divider board. Checked the hole where the water...
at the back of the fridge there is a water drain hole. this will be blocked. you will have to unblock by pushing a thin wire etc down it, then pour a little warm water down to confirm it has been unblocked. if otherwise
There are two issues that may cause leaks near the door of your fridge. The fridge door may not close in full or the rubber gasket which encompasses the door frame may be clogged or torn, thus causing condensation and leaks. To repair this problem, you need to discover the faulty component. If the gasket is dirty, clean it by rinsing with a sponge. Check if an item in the refrigerator is preventing the door from closing properly. If the gasket is somehow impaired, replace it. When buying a new gasket, it is best to buy one that matches your fridge model or type of door. The more general the gasket, the harder it is to install it.
If the leak caused by the gasket, you may have to check the door and ensure that it closes tightly. If it does not close well, you may use the door screws and bolts to fix the problem. Another remedy is to put the refrigerator at a slight angle. Some fridges have adjustable legs, but if your model does not have such, you may want to buy some wooden shims or sheets of plywood and put them beneath the fridge.
Fridge Leaks due to the Drain Pan
The drain pan functions to catch water from condensation so that it does not leak over the floor of your kitchen. If the drain pan is somehow damaged, it may be the reason why you have a puddle of water around the fridge. The pan is located underneath the fridge. Pull it off, drain the condensed water from it, and check if there are any punctures into it. If there are some, you should buy a new pan or somehow repair the current one. One possible way to check your drain pan is to fill it with tap water once you have cleaned it.
Hope this helpout.......
Jul 28, 2010 | Refrigerators
Water dispenser makes cluking sound
I set fire to my house and claimed the fridge on insurance.
however I was uninsured and now require financial assistance.
please send
1. $2950 so i can buy a new fridge
2. $0.05 if you are concerned about my mental health
3. an insult if i am wasting your time.
rgds..John
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
