Question about Canon IR 2525 Digital Copier
I finish servicing my canon ir2525 and it refuses to pick papers when i try photocopying
After, it tells me on the display to "insert the Drum" Please help me
  • 18 Answers
SOURCE: errror e170
Sure you didn't mean E710?
710 is a DC Controller problem.
Posted on May 26, 2008
  • 1362 Answers
replace the fuser lamp or the thermofuse.
E000 fuser problem.
Posted on Dec 12, 2008
  • 318 Answers
SOURCE: error code E000019-0000
Hi this is only indicating a dirty waste toner bottle neck.
It is easy to solve.
Take a star screwdriver,remove the one screw of the left lower panel.You will find the panel at the left-lower side of the machine,the side were you have to open to remove paper jams on the fixing side of the machine.
After removing that panel,remove the bottle remove the toner inside the bottle clean the NECK of the bottle inside and outside and put the bottle back in it's place.Put the panel back and switch machine on and off.
Posted on Mar 10, 2009
  • 92 Answers
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
Posted on Nov 02, 2009
  • 1219 Answers
SOURCE: Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Posted on Jun 30, 2010
I have a canon ir 1018j black and white photocopier that does not pick a paper nor photocopy
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
Sep 05, 2016 | Canon IR1018J Black and White Copier
My copier canon ir2525 legal size paper jamming problem half paper exit unit out half paper exit assembly in A4 size and A3size 100%perfect exit plz solution this problem
Most common jam problems are caused by using thin paper 80g density or less. Recycled paper is the worst as it tends to tear easier as the their is only 20% new cellulose fibre in it and 80& is paper mache'. When using recycled paper, use min 100-120g weight papers and your jams will disappear.
May 29, 2015 | Canon Office Equipment & Supplies
Why does ir3300 canon photocopier show paper jam between the lower tray and right cover yet no papers jamed and even else where, what could be this?
these also can occure if the paper from the cassette isn't picked up or if the paper pass the cassette and exits but sensor flapper has slow response.
As first step I would recommend to change the paper pick-up, feed and separation rollers in cassette.
Remove the cassette out, look inside, on inner right side you will see 3 tire rollers. Each roller has nose with plastic hinge. To remove him you need to push hinge on the nose and pull out the rooler to a side.
If they are worn out they will be smooth.
You can remove the rollers from the tray that works and put it into troubled one for test. If the paper jam doesn't occuress you are sure that you need new rollers.
If not I recommend to call service.Because, also the problem can be in paper lifting claw, broken gears,...
For service manual you can contact me on
Hope that helps!
Sep 01, 2011 | Canon Office Equipment & Supplies
Paper is not being picked up and fed through.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Nov 20, 2009 | Canon PIXMA MP510 All-In-One InkJet...
My canon mp830 when printing picks up two or three pages, printing only on the top page. this happens on and off.
try using a better quality paper designed for printers rather than photocopy types. Also it is recommended to "FAN" paper like playing cards before placing into tray. Do this to both top and bottom of paper **** to reduce static in paper which causes it to stick and pull in more than 1 page Frrrrp Frrrrp
please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon NP 6650 photocopier. Begins to pick up paper, stops and gives message about jammed. Checked path and see no paper or parts of paper. Need service manual.
1)jammed issue.
2)can u try to make copies by using stack bypass or other paper deck see whether u hav the same fault.
3)or flip over your paper and put it in the paper deck again .Fan the paper ,it could be high moisture and static on the paper.
4)clean the paper dust from the pick up unit with damm cloth.
Sep 04, 2009 | Canon Office Equipment & Supplies
Consant paper Jam - Canon 1600 photocopier
Try to clean the rubber parts. Probably these are filled with paper dust.
Jul 22, 2009 | Canon ImageRunner 1600 Copier
How to photocopy double sided A4 sheets?
you copy first side normaly. then on left side open bypass deck.Put the paper, so that the side on wich you want to print is down. Automatically when you put paper in bypass, the machine ask you wich format is it ( eg. A4 ), confirm with OK, then you need to tell machine wich type of paper ( eg. plain paper ) and OK. then green copy key.
May 02, 2009 | Canon iR 1600 Laser Photo Printer
Canon IR 2525 Digital Copier Logo
21 people viewed this question
old marine
old marine
