Question about Dishwashers
Hi .it pumps out ok ..and yes i know it always leaves some water...however when it has been sitting unused for a while i end up with water all over the floor ans a full diswasher
Lg ld2120w
    Top Expert:
  • Dishwashers Master
  • 50,010 Answers
The problem indicates that there is a problem in the water control shut off valve diaphragm
there is a leak that when the machine is not in use is still filling the machine
Posted on Dec 17, 2016
I have a Whirlpool dishwasher Type 583-1 Model WDT720PADM2. It is suddenly not washing or drying well. Leaving bits of food and layer of film on dishes/glasses. Soap is sometimes not dissolved.Help!
Assuming the machine fills and drains water ok, and is heating the water too, and you can hear the circulation pump running during the wash, the most likely problem is blocked jets in the spray arms. You have to remember that a dishwasher is NOT a garbage disposal unit, and plates must be scraped clean before they are put into the machine for a wash. Bits of uneaten food in the machine will clog the filters, coat the walls of the machine and work their way into the spray arm jets especially at the very ends. These end jets are the only reason the jets rotate, and if blocked the arm just sits still and poor washing results. Remove and / or examine the ends of the spray arms carefully - often fruit pips or pasta can be seen blocking the jets. Remove this with a pin and running water. Also then run a dishwasher cleaner through the machine, with No load in - do this regularly to reduce blockages and smells.
spray arms can be taken to pieces in most cases to clear blockages. Always use a top quality detergent in the wash for best results.
Feb 03, 2018 | Whirlpool Dishwashers
Miele Dishwasher 626 SC starts but no water is received and it stops soon after. Water supply is ok and has pressure. Main solenoid is also ok. Any suggestions?
Is the drain pump working? is it fed to a sink trap and end hasnt been cut out.i know but ive had this happen when sent to check a machine!pump is always first part of program
Apr 17, 2017 | Miele Dishwashers
Machine will not finish any wash cycle, It stops, illuminates END light and beeps? Is there a reset or is this at the end of it's life?
Hi, quite often cycles are not finished because the drain pump has an intermittent fault. It may pump ok at the start of the cycle but towards the end it's had enough and stops. Leaving water in the bottom of the drum. If this is similar to your machine's symptom then I would be checking the pump. They are cheap to buy and easy to fit.
Hope this helps you.
Oct 04, 2015 | Washing Machines
Hydro-Quip pack in my Hydro-Spa hot tub no heat.
3 Flashing dots (display) - Water flow problem check for closed valves, dirty filters, water level, pump/wet end operation/defective pressure switch.
If your spa has been off for a while its likely something is blocking the lines.
Flashing dots & Lit light on display - Hi-limit trip, reset power to clear.
Nov 16, 2011 | Hydro Quip Inc Pool & Spa
Hi, Bought a Maytag front loading washer #MAH6500AWW about 5 years ago. 1. The amount of water remaining in the machine (if you turn the drum it sounds like SEVERAL gallons of water swooshing around)...
i would say the drain pump is blocked.......... you could take the drain hose and leave open end at lowest point on the floor into a container and let water drain out..........easier if you can get machine to outside door and let water drain outside i did a zanusi last night...stuck in the pump was 9 small coins 1 hair grip and a womans bra under wire............
follow the waste hose at the back of the machine it ends at the pump......... open the pump then check it out...
good luck..
cheers
Apr 04, 2011 | Washing Machines
GE Model GSD600D03 has been sitting unused for 7 month, motor works, but no water is pumping. Please advise.
First off, are you certain the motor is running, or just humming ? I ask this because it is quit common for this make of dishwasher, especially after sitting idle for a period of time. It`s a fairly easy solution though.
I'll tell you how you may be able to fix it. It works 95% of the time.
**Shut off the power to the unit**
Remove the lower access panel/toe plate. There should be either 2 screws or 4, depending on it's era. Once you're able to see the components below, fill valve, pump, lots of wires etc. get yourself a flashlight or trouble light. Single out the main wash pump & motor assembly (it should be straight ahead with a black coil and linkage on the side of it) Now you have to identify where the pump & motor meet in the middle, it's where the metal motor ends and the plastic pump housing begins. (make a note of if it's been leaking at the motor & pump joining point while you're at it, you'll see evidence if so. If it has, you'll need a new impeller & seal kit, but that's for another day)
At the end bell of the motor is a cooling blade or fan if you will. (It is a cooling device for the record) Reach in and physically push/pull on it in either direction until it "breaks free". **careful the edges can be sharp.** You'll know when it does, because it will seem easy to turn at that point. Once you've done that, turn the power back on and give it a try.
Hope that helps, let me know either way. Thank you for visiting "fixya" today.
Good Luck,
macmarkus :)
Jan 24, 2010 | GE Dishwashers
Dishes are not always dry, even after sitting overnight
hi
make sure you are using rinse aid as this helps to evaporate the water at the end of the cycle in the drying stage. I know tablets have rinse aid built into the tablet but this can wash away on some wash cycles and do nothing so even if you are using tablets i reccommend still using rinse aid.
Jan 24, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Dec 30, 2009 | Kenmore 42822 Front Load Washer
Yamaha k-720 cassette deck
No play but fast forward and reverse work ok--yes it is the drive belt. I disassembled the unit to find that the belt is actually sticky and stuck to both weighted flywheels, the drive motor pulley and managed to stick to itself. The drive motor is warm from trying to turn. Now, anyone know where to find the belt??
Nov 28, 2007 | Audio Players & Recorders
Dishwashers Logo
Top Dishwashers Experts
