Question about Pool & Spa
Eaquip chlorinator manual - Pool & Spa
    Top Expert:
  • 8,211 Answers
  • 1 more comment
  • NOEL
    NOEL Dec 17, 2016
    sorry it was not there i will have another look around if i find anything i will get back to you.
  • NOEL
    NOEL Dec 17, 2016
    is there any model numbers you can give me please i am finding manuals on that site but not sure what one to go for.
  • David Weller Dec 17, 2016
    only that it is auto clean model
Vx salt chlorinator has suddenly stopped working fully, when on manually it just stays in sanitising mode. Every thing is fine chemical wise and pool level but output of chlorine is not happening
look for corroded valving or white powdery residue thatgs got the piping/hardware plugged up..may need replaced if you cant brush it off..
Jan 06, 2014 | Pool & Spa
I have a 30 amp Eaquip salt chlorinator which is displaying a P6 error. Can anyone advise me what this may mean please? Chlorinator does not appear to be working.
should be a error sheet inside door or call who you bought it from
fist make sure salinity in water is correct try cleaning sensot with 4 parts water 1 part muriatic acid then try to clean cell the same way should work then if not call professional
Oct 30, 2013 | Pool & Spa
My salt water pump keeps saying low salt. I have had the water checked and there is plenty of salt. I have cleaned the cell and it still says low salt. The pump is on;y 1 year old. I dont know what else to...
I suggest you clean the cell according to manual and try it then. If it keeps producing chlorine then keep swimming. If the pump is flowing water fully (if not clean baskets and filter) and it can't keep the chlorine above 2 ppm and you have 30 to 50 ppm stabilizer in the water then there is a major problem in the chlorinator. I don't trust the salt indicator on some chlorinators but that is less important than if it chlorinates. You can but salt test strips. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Free Chlorine won't register in pool?? I have done everything the manual suggests and cannot get a reading on chlorine from my pool. If you check the water coming directly out of the generator it...
if getting reading from unit and losing by the time it gets to pool water chlorine is locked need to add non chlorine shock to oxidize and super shock pool
Sep 02, 2017 | Intex Automatic Salt Water System for ...
Intex salt water chlorinator I added a higher flow pump and chlorine levels seem low no matter how many hours I run the chlorinator
your pump has nothing to do with chlorine generation.
You need to get a salt test kit that reads in #'s not colors.
Now get your salt to 3000ppm or as close to it as you can.
The amount of salt reccomended in the manual is just a starting point
any lower than 2800 and you will not produce enough sanitizer and over 3600 and your pool can go cloudy, taste bad, and rust metal parts
Jun 28, 2010 | Intex Automatic Salt Water System for ...
I opened my pool a couple of weeks ago and filled my Hayward CL200 chlorinator with 3'' tablets. I usually set the dial on 2 with good results. After over a week, the chlorine level was nill in the pool....
A CL200 Involves direct injection of chlorine into the pool. Water passes through the chlorinator and goes to the pool with chlorinated. WIth the 200 (Not the 220) I've only seen a handful with problems over the years with chlorine not dissolving. If the chlorinator is not leaking, and the control valve is moving freely here's what I'd recommend.
1. Are you using a new type of tablet?
If so remove the tablets and place into a floating chlorinator.*** WARNING Wear Rubber Gloves, while handling wet tabs****
Dial it all the way open. If the tablets don't break down at this point with in a day or two, They were over compressed at the factory, potentially have to much filler (most slow tablets should be 95-99% cholroine) or the water is too cold ( below 70 deg. This should not be an issue in July) If this is the case switch brands.
If the chlorine is dissolving in the floater but not the chlorinator it could be one of the following.
1. Make sure the direction on the chlorinator is correct inlet (from Filter) to outlet (to pool)
2.. In some of the newer 200 chlorinators there is a built in check valve you can see it in the bottom of the chlorinator You will notice a threaded piece in the bottom that contains a white plastic ball the size of a pea. If this ball does not move freely to the touch, odds are the filler in your chlorine has clogged it from moving, thus preventing the flow of water from dissolving the chlorine.
You can check this by removing the chlorinator from the pool, removing the lid and pouring water directly into the top. If you do not see water passing through to the "Outlet" side of the chlorinator a clog is most likey your problem.
I've seen clogs cleared with wire coat hangers and hot water. Be forewarned that hot water being poured into a chlorinator will cause the any residual chlorine to gas off, make sure you do not have you face over the chlorinator when you add the hot water and you do so in a very well ventilated area. A straightened wire coat hanger can be used to dislodge any obstruction in the check valve and "get the ball rolling again"
Hope it helps.
Jun 10, 2009 | Hayward In Line Chlorinator 9 Lb. Capacity...
Pool & Spa Logo
118 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
