Question about Fantech SHR 14104 Heat Recovery Ventilator HRV - 1410 CFM, 3 Speed
My Fantech HRV started making a noise that sounds like water draining from the bathtub. I need to know what's wrong with it, thank you.
It's about 10 or 11 years old.
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
Goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
The flame sensor needs to be cleaned. This video might help you understand how to clean the flame sensor.
Oct 05, 2012 | Goodman Manufacturing Goodman GMH950704CX...
My holmes air purifier makes a screeching sound
If you can access the fan, spray lubricant onto the shaft as close to the fan body as possible. It will work it's way into the bearing
Apr 14, 2012 | Holmes Products Air Purifiers
Is there any health issues with using a Living Air Filter in your home? A couple of years ago, I heard there was legislation being proposed to ban their use in California.
California Air Resources Board was paid to ban any non-commercial Ozone-producing machines from being shipped into the state. Volarra, didn't want to spend the money to DEMAND they produce a list of injured parties, ALWAYS a part of any ban on a product. When I called them they said they knew of no injuries or medical lawsuits. I've never heard of any...after 9 years. Green Environmental Technologies installs the Space-Certified part into Hospital Surgical rooms, the OLD ozone technology got rid of my 2 boys teen-room odors and they stopped using their inhalers. Went from 4 per month for 15 years for the both of them, to 4 per year. GET also went to the Atlantis Casino and purified their KENO room with a single OLD technology commercial unit. They've been commercial certified, mold certified, have a PhD on staff, with partners across the country. This technology is good enough to fight a toxic chemical spill, so YES there's a chance that you could overuse it. But like the water tap, you should learn the symptoms of it being too high. Headaches, pool bleachy smell, sore throat in the morning that goes away pretty fast. These machines are supposed to be on as LOW as possible!
May 11, 2011 | Ecoquest Fresh Air Air Purifier
I bought a used Austin Air HealthMate and it has an awful smell coming from it... it's similar to the fragrance that was in the house we purchased it from. We've had it running for over a week near an open...
I have the same problem although I figured it was due to the filter being close to five years old. I have had the Healthmate since 1996 and the current filter is 4 1/2 years old. The unit is in my son's room and I had noticed for a while (maybe the last 6 months or so) that his room had a foul sour smell to it. My wife & I thought it was our son as he is close to puberty and starting to need deodorant but I took the unit out of his room and the smell is gone. I'd be willing to bet that both you and I need a new filter.
Jan 18, 2011 | Austin HealthMate Air Purifier
My SS-4X does not seem to discharge anything. It is about 3 or 4 years old. L Jundt
Contact they helped me with repair information for my Aranizers.
Jul 25, 2010 | Aran SS-4X Air Purifier
Trouble indicator came on after a power outage and
When was the last time the backup battery was checked? The trouble indicator could mean a weak or non-working battery. If the system is 12 years old, the battery should be changed.
Mar 07, 2010 | Air Purifiers
Cleaning tips for my Brookstone Pure Ion
I have Bridge Stone Ionic Air Cleaner and I cant figure out how to take it a part to clean the filter. It's a few years old, used very little and I don't have a manual. Can anyone help. thanks
Nov 06, 2009 | Brookstone Pure-Ion UV Air Purifier
Our Eco-Quest Breeze no longer works. I cleaned
I've seen several like that and found the wire connections corroded off. Easy to fix if that's the case. Make sure the unit is UNplugged before taking it apart.
Sep 03, 2009 | Air Purifiers
Fantech SHR 14104 Heat Recovery Ventilator HRV - 1410 CFM, 3 Speed Logo
137 people viewed this question
Top Fantech Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Fantech Air Purifier Expert? Answer questions, earn points and help others
