Question about Kenmore Refrigerators
I have the same fridge Kenmore sold under Sears Canada Model # 501-77312 . Bulbs check out and the upper mounted switches seem to check but fridge bulbs will not illuminate....Control module perhaps?
A few yrs ago it did what many of these apparently have...the lights stayed on although doors were closed and nearly started a structure fire ,warping and melting light cover and control panel unit
  • 210 Answers
SOURCE: The control panel light blinking and ice trap door will not close
Sounds like you need a new display pwb. The flapper for the ice works on a solenoid which is on a little board that is behind the display board. When the power is cut the flapper should close as it is on a spring. I don't believe that there is any worries of it catching fire. Have a tech come and replace the board for you.
Sgt 48
Posted on Jun 04, 2008
MNTECH
  • 1543 Answers
SOURCE: HAVE AN LG FRIDGE MODEL LRFC22750. THE LIGHT
EFFECTIVE FROM(SERIAL NO.) from 704MR***** to 801MR***** Subject Lamp Cover Melting Improvement (LG 3D Basic) / 2nd No. Loc No. Before Change After Change Note K-Code Remark Part No DESC./SPEC. Part No DESC./SPEC. 1 501A 6871JK1011A PCB Assembly,Main /
6871JK1011D PCB Assembly,Main /
WINNER1 DISPENSER ENERGY STAR '08 C 3 Change Relay SPEC. 2 503F 3111JJ1001X Case Assembly,Display /
WINNER1 BASIC BRAND ABQ33905315 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 3 503F ABQ33905304 Case Assembly,Display /
SOLO PARA SERVICIO, NO PARA PRODUCCION C 3 Thermoprotector addition. 4 409B 6912JK2002C Lamp,Incandescent /
60W 120VAC 0.40A 480LM - WHITE 6912JK2002E Lamp,Incandescent /
C 3 60W to 40W
Posted on Jun 12, 2009
SOURCE: Light bulb stays on in Kenmore Elite fridge Model # 795.77559600
I had the same problem with a kenmore elite fridge and recieved the same response from Sears customer service!!! File a complaint with your local BBB. Sears contacted me within the day and sending out a tech at their expense only after the complaint was filed. Good luck. Elana
Posted on Aug 13, 2009
localwonder
  • 6784 Answers
SOURCE: lights stay on in fridge
HI. The door switch will be the culprit here.
The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
Posted on Dec 11, 2009
  • 161 Answers
SOURCE: The light bulbs inside my
You have a bad main board with a relay stuck shut. Call an LG dealer and ask them if there is a service bulliten on your model. If there is, your parts are free.
Posted on Jan 22, 2010
Testimonial: "This is exactly right. Both the parts and labor were covered by LG, even though the fridge is almost 3 years old."
Hello! I have a very old Kenmore washing machine, and cannot seem to find any parts list, or even evidence that it exists, online. I need to fix the timer! I have the model & serial #s.
it seems that if you cannot trace the Canadian manufacturer on line then there is only one possibility to send me the part to fix as I am into electronic PCBs repair, and don't forget the mains dropper transformer you need for that voltage and wattage, you would have to get in touch with the website to get them to contact me for your or my web address eric
Jan 08, 2018 | Kenmore Washing Machines
Kenmore ref model 795.73266303. After power outage fridge won't turn on. Lights inside work but the digital thermostat is off.
Check the parts list at the link below to see if a circuit breaker is present in your fridge, it could have tripped if incoming line problems were unstable:
KENMORE TOP MOUNT REFRIGERATOR Parts Model 79573266303 Sears PartsDirect
You can also order needed parts from those pages.
Jun 25, 2015 | Kenmore Refrigerators
Sears/Kenmore (Canada) Model# 970-681821 . Anyone know manufacture date and if there is an Owners Manual available?
Hello Anna Dee;
My name is Peter. I am a retired field service refrigeration technician.
What a run around! Look on the inside of the fresh food section of your refrigerator. There is a label on the wall near the top. The date of manufacturer is on the label. Also the correct model number. Send me the model number.
What is the problem? Refrigerators are not designed to operate in a garage. If you purchase a new unit and it was under warrantee, the warrantee would be voided if it were operating in a garage.
I was a Sears field service technician. I have never heard of a garage heater kit.
Sorry, you got the run around. The customer service people are under trained, and the telephone technical personal have never spent a day in the field.
I live in Glen Burnie, Md. Call me 443-306-1362
Dec 08, 2014 | Kenmore Refrigerators
Sears Canada bought Eatons Canada back in 2002. Eatons sold Viking products. I bought I Sears Viking over the range Viking microwave built in 2002. Nomeclature # 851.8250800 Model # 82508 Ser#...
This is a Sanyo microwave. the "851" number is the manufacturer number or "source" number. I can't tell you any more about that particular model.
I would remove the circuit board (control panel) and check for damaged/burnt copper print. Where the copper is burnt, you can solder on jumper wires to complete the circuit.
Mar 01, 2011 | Kenmore 80492 / 80494 / 80499 1000 Watts...
Have a Kenmore electric range. A model C880 sold by Sears Canada. One of the "element on" indicator lights stay on even though the elements are not switched on.
This is usually the infinite switch has failed. They are easy to check and inexpensive. Here is a video that will walk you thru testing an infinite switch. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
Oct 23, 2010 | Kenmore Kitchen Ranges
Jul 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Model 363 makes Clunking sound
sounds like the mount may b loose.(motor mount)
If so you may want to get under the machine and check to see if there are some screws missing or lost. (they may b on the floor rite next to the motor;)
good luck;)
Feb 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore lid switch
The following link explains how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Now, unless someone has modified the original lid switch, there is NO soldering required. The defective switch just has a couple of mounting screws holding it in place, along with a ground wire attached to the casing. The entire assembly unplugs from the timer and comes out.
As far as a replacement is concerned, you can order them on line at searspartsdirect.com. Just type in your complete model number (located around the wash tub opening) and the lid switch is usually listed under the "Top and Cabinet" heading. If your lid switch is activated by a lid strike, which is mounted on the washer lid, make sure it is also intact and not broken. The strike is also listed under the same heading. If you do not wish to wait on shipment, take the part numbers listed on the Sears website and go to your nearest appliance parts retailer. These are standard parts that can commonly be found there.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 28, 2008 | Kenmore 24032\24036 Top Load Washer
Light Switch Stuck
This is a replaceable part. A new switch can be ordered from Sears by Model number of your refrigerator and name of the part. If you have your owners manual it may contain a list with part numbers. Some of these switches will pop out to be replaced. Others you may have to remove the breaker strip where it is mounted to remove the switch by compressing the snaps on the side of the switch.
May 07, 2008 | Kenmore 60721 Refrigerator
795.77573600
I just saved my fridge / home too, smelled what I thought to be an electrical fire when I opened the Trio doors, immediately looked at the bulbs as a probable cause, and sure enough, the base of the bulb sockets were burned-brown and the plastic housing was to hot to touch without a hot-mit.
Unscrewed the bulbs and set aside out of children's reach and combustable materials.
I'm filing a complaint and service repair today. 8/3/08
Sean-Jon
Nov 07, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
