Question about Mitsubishi WD57831 Television
Mitsubishi wd57831 turns itself off and red light stays on
It all started when the unit will turn itself off. when i turned it on today,  picture was unusually dim. i unplugged the unit then plugged it back in and all i got is just the audio, no video and the red light stays on. please help.
Re: mitsubishi wd57831 turns itself off and red light...
Sounds like the lamp is burned out.If you are handy with a screwdriver, you can replace yourself. best price i found on mine was at, rens about $160. hope this helps
Posted on Mar 22, 2009
0 characters
3 Points
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Projection Televisions
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My wd52327 turns on and than turns itself off
Thats a very common problem which means that the capacitors on the power PWB have most likely failed. You can get the repair kit which has the replacement Capacitors and step by step instructions with detailed pictures on how to do the repair . Heres a link to the repair kit for your model.
Jan 24, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
Lamp lite
Does the lamp indicator stay yellow, or does it turn red?
May 17, 2008 | Mitsubishi WD-52531 Television
Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Jun 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD57831 Television Logo
419 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
