Question about Mini Computers & Internet
On seneo mini keyboard how do you delete something
How do I get the keyboard of my Ipad mini to drop down it is stuck at the top of the page and has split in half
In the lower right of the keyboard is a keyboard key (it looks like an icon of the keyboard). Touch and hold the keyboard key. After a second or so, word choices will pop up saying something like "Dock" and "Unspilt". Touch one of the words. If you want to do both actions, repeat the process for the latter.
Feb 19, 2015 | Apple iPad Mini
Why is the tablet always out of space?
Delete all "sent" E-mail messages.
Delete all "picture-with-text" messages.
Feb 09, 2015 | EEEKit 2-in-1 for Android Tablet, for Dell...
My delete key is not working on keyboard but fine on screen key board on HP mini
tap the iPad on a bench lightly and while pressing on the broken button slide your finger across the button lightly trying to loosen anything under the button
Jul 27, 2014 | HP Mini 1000 Netbook
The keyboard shows a connection but nothing happens on screen.
Delete device. reinstall. There may be a setting in the device manager that lets you use only one input method. So if the original keyboard will over ride? All this guess work would be eliminated if you give the os pc specs. If it's an external keyboard on a desktop then you may need to disconnect it? A laptop lets you use more than one input keyboard or wifi mini etc.
Oct 17, 2017 | FAVI Entertainment Mini Wireless Keyboard...
Cannot log in, keyboard wont type passwaord hp mini 210
Well sounds like somebody may have spilled something in the keyboard. You can get a replacement for about $20 or just plug a usb keyboard in it.
Aug 09, 2011 | HP Mini 1000 Netbook
When I connect to the internet my Hp mini 11o hangs..also sometimes a blue screen error
If you re having problem or issue on internet connections you may try to do this.
Delete cookies and temp files on your computer.
Deleting cookies:
1. Click the Start button.
2. In the Start search (or Search for programs and files) field type in "shell:cookies" without the " ".
3. Click Ok or press Enter on your keyboard.
4. A new window will open and will give a list of text document files.
5. Delete all the files in the folder excluding the "index.dat" file by selecting all of them then press
the keys "SHIFT - DEL (Delete)" on your keyboard to delete the files permanently.
6. Close the window after you have deleted all the text document files.
Deleting temporary internet files:
2. In the Start earch (or Search for programs and files) field type in "%temp%" without the " ".
4. A new window will open and will give a list of files.
5. Delete as many files as you can in the folder by selecting all of them then press
6. If there will some items that cannot be deleted, that's alright, you can SKIP deleting them.
7. Close the window after you have deleted most of the files if not all.
Disk Clean-up:
1. Click on Start, and then click My Computer or Computer.
2. Right click on Local Disk (C:) or OS (C:) and click Properties.
3. Click on Disk Cleanup.
4. When another window appears, put a check on all the boxes then click OK.
5. Wait until the cleanup is finished then close the window.
Try to check as well if its applicable on certain browser. Try using a different browser.
Or you may check with your ISP if there is any internet connection issue.
Apr 06, 2011 | HP Mini 1000 Netbook
My keyboard wont work. I am not able to type anything.. it was working earlier? did I lock it or something? what happened?
first of all try to connect external keyboard if its working then replace ur internal keyboard and if external keyboard is not working then then motherboard is faulty may be keyboard connector is faulty or keyboard controler chip is faulty
Mar 17, 2011 | Dell Inspiron Mini 9 Notebook
My backspace only deletes one leter at a time
of course your backspace button only deletes one letter unless you press the backspace button for a long time and it still deletes one letter. There is something wrong with your keyboard.
May 12, 2010 | Dell 0Y3740 Keyboard
Numeric Keypad also deletes
You might have a keyboard virus or something.
Because its kinda weird to have a keyboard problem which makes your keyboard numpad become delete though.
Apr 10, 2009 | Microsoft Wireless Desktop 3000 Keyboard
Computers & Internet Logo
37 people viewed this question
Top Mini Computers & Internet Experts
NOEL
NOEL
DROPNDEAL
DROPNDEAL
Are you a Mini Computer and Internet Expert? Answer questions, earn points and help others
