Question about Bosch Washing Machines
How do I fix error code E2 on a Bosch front loader?
SOURCE: e13 error code with my
I had an E-13 error code on my Bosch 500 series washer.  The drain pump  impeller was plugged.  Access the drain impeller at the bottom front right corner.  Just put a pen in the hole and turn the cover.  Then you need to manually drain the washer.  I used a shop vac by just turning the cap until it started to leak and vacuum the water as it comes out, this takes quite a while.  When you get it drained you can take the cap completely off.  When I did I found a wipe in the impeller.  I took it out and put it back together and the washer worked just as before.  Good Luck!!
Posted on Mar 24, 2009
SOURCE: What does error code E2 mean? I have a Bosch Maxx
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Posted on Nov 25, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
tbirdfan1
  • 3051 Answers
SOURCE: I have an error code
Hello there
Normally this is a drainage problem code
Unplug the machine and wait for 30 min
During this time Remove the cover on the front bottom right corner or the front cover at the bottom , use the small hose that is attached to the pump to drain the water, from the pump then unscrew the large drain cover and remove the blockage from the drain pump. and any additional hoses then reattach the hoses and then plug in after the 30 minutes is up then press the cancel button and test ...Test by pouring 1L water into section II in the top and setting the machine to 'drain'. it should beging to drain
Posted on Mar 07, 2011
  • 6277 Answers
SOURCE: i have got a bosch
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 30, 2011
What is error code e04 bosch front loader washer
The "E04" error code on your Bosch washer refers to a drainage problem as you may or may not already know. ( it can mean door lock error, but that is usually a by-product of it not draining )
What you may have is either a partially clogged pump, or a faulty pump...the later being the least likely
Nov 22, 2016 | Bosch Washing Machines
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
Whirlpool error code e2 f3
The error codes are in the operating instructions if you don't have it ask Bosch to email the error code page to you.
Apr 10, 2014 | Bosch Cooktops
Kenmore elite smartwash quiet pak 4
This video will show you how to change a door seal on this Bosch front loader washing machine
You can find more Bosch videos in our Bosch repair channel
Jul 22, 2013 | Kenmore Elite 45986 Front Load Washer
Error code e2. inlet water temp sensor. any one have to fix this?
Before calling service technician, open following link for Bosch troubleshooting resources, including error codes, manual, Bosch contact info, and service bulletins.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Error codes are starting point for troubleshoot.
e2 is cold water temperature sensor fault.
Bosch error code says: 1) Check connector on wires coming from top of water valve for a secure connection.
2) Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions Any damage due to freezing conditions is not covered under warranty.
Another contributing cause can be temperature thermostat set very high and tankless sensor is going bad, and very cold incoming water, or combination of factors above.
Also read manual for advisories and required maintenance. Some units require water filter be cleaned monthly.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 28, 2011 | Bosch AquaStar 2400ES-NG
What does error code E2 mean? I have a Bosch Maxx Classic.
Nov 03, 2009 | Bosch Washing Machines
Bosch washer error code e3 what does it mean?
Error "E3" on a Bosch front loader means there is a problem with the door. Either it is not closed properly (user error or a blockage) or the locking mechanism has a fault. Check to see that there is no object shoved in the latch hole (our 2yo just did that) preventing the door from closing properly. If it is not that, a technician is advised. I tried to get into the machine to fix out issue but could not get to where the issue is.
Aug 02, 2008 | Bosch Washing Machines
Washing Machines Logo
24 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
