Question about Miscellaneous
I'm looking for a manual for a Snowflake 318-852-500 serial # 0574285. Can't seem to find anything on it.
Its a 10/28 and with snowtrax
What does the snowflake mean
Cold Rinse? The plates come out ready to use rather than being hot.
Aug 13, 2015 | LG Dishwashers
What is the red light that looks like a snowflake
The snowflake appears when the outside temperature drops to 40 degrees or below, it then changes to red when it is 32 degrees and below. It seems the manufacturer thinks this will assist you with your driving habits on frozen roadways.
Dec 20, 2010 | 2001 Mercury Cougar
What are the three settings - one looks like a snowflake, one looks like a drop and the third is a fan. The room seems so humid but cool
The snowflake is cooling, the drop is a dehumidification setting, and of course the fan is fan only..
In your case use the dehumid setting...
heatman101
Aug 10, 2010 | Samsung AW0603B Air Conditioner
What does the hold signal with snowflake mean in a 1998 subaru fo
This explained in the owner's manual, but very poorly.
I have asked all sorts of "Experts" from Subaru techs to forum posters, and received a half-dozen different answers.
As far as I have been able to determine, operating the "Hold" switch does a couple of things.
It is only relevant in "Auto", and not "Sportshift".
It starts off in second gear, rather than first.
It will hold the car from rolling back on a moderate upgrade.
It "seems" to me to "smooth out" the gearshifts.
All of this, as far as I can understand, is to avoid sudden changes to traction in snowy / icy / wet conditions. Starting off in first, for example, would cause instant slippage, starting in second is less likely to. Engaging forward gear while rolling backwards, likewise.
I am not an expert, nor a mechanic. These are only my observations, and "sifted" knowledge from many different sources...
Jan 01, 2009 | 1998 Subaru Forester
Hi there can someone please tell me whats going on with my car??? I have an 08 cmax petrol and now the cold weather has kicked in on my dashboard is a snowflake appearing and bleeps at me now and then what...
hi there the snow flake ur on about on ur dashboard is just a indicator to tell u that the temp outside is below freezing which shows red or amber which goes on about 4degrees which is also a warning to take care on roads which might be icy. hope that helps
Dec 03, 2008 | 2000 Ford Focus
Why is the ''snowflake light'' showing up red in my car?
I have a '99 Mercury Cougar & I've been read somewhere that the snowflakes have to do with the outside temp. & traction. I think it's warning you that it may be slippery or icy. I've noticed that when it's +3 to about -2 or -3, the yellow snowflake shows up. Any anything colder than -3 shows the red snowflake. The other lights: the wrench comes up in yellow. That one has always turned on after a certain amount of km's & it's advising you that your car needs a check-up (that's when I know I should look into getting an oil change). You can turn this light off by holding down the two buttons above & below the 'clock' button. Hold them down together for at least 5 seconds & that wrench light should go off. Otherwise, there is a light for checking your breaks (upside down exclamation mark), low windshield fluid. I can't think of any other ones but I hope this helps.
Nov 18, 2008 | 1999 Mercury Cougar
Yellow warning light
Dunno where you reside but our indoor/outdoor digital thermometer shows a snowflake once the temp drops down to 0C/32F. It wouldn't surprise me to learn that a Jag would have a warning light for freezing temps.
Nov 16, 2008 | 2003 Jaguar S-Type
Miscellaneous Logo
19 people viewed this question
Top Miscellaneous Experts
Gene Haynes
Betty Kent
Betty Kent
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
