Furnace will not fire up does not do any thing model m1mbo7oa serial no m1a131005987
Furnace wil, not ignite when calling for heat
For this answer, we need a model and serial number.
Generally, be sure the power is on, does the heat moving device run? (Fan for air, or pumps for water)
Nov 02, 2017 | Heating & Cooling
Miller furnace says pressure switch is open
you have a bad VPS-Vent Pressure Switch- it monitors oxygen and gas mixture to allow furnace to fire up-- you can get part at a local Heating and AC supply house just call and give model and possibly serial number and they can tell you if they have the part and cost.
Oct 25, 2016 | Heating & Cooling
I am looking for furnace wiring diagram
What is it gas fired /oil What make model serial # ?
Oct 27, 2015 | Heating & Cooling
Where is the reset button for gas furnace serial # MGH9301-02963
Normally there are no reset buttons on most furnaces. There are two burner rollout switches, those are the only manual reset buttons on the furnace.
To reset your furnace, turn off the fuse or breaker to the furnace, wait a few minutes and the fualt will be restored. If the furnace tries to start 3 times and does the exact same thing, then you have problems
Feb 02, 2015 | Heating & Cooling
Is it cost effective to replace draft inducer blower on 22 year old furnace?
Depends on the cost to repair. Probably a 22 year old furnace is not very efficient also. Take every thing into consideration.
If it still works it may work for a while but you don't want a break down in the middle of winter.
Nov 07, 2014 | Heating & Cooling
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
Request the date of maunfacture of my Hunter Comfort RB 115 oil fired hot air furnace, the first serivce date from the furnace oil supply company service man was 20/05/97. ULC - 742 Thanks
If you have or can find the serial number of the furnace, you can contact Hunter directly and they can tell you the manufacture date. Their contact information should be on the Manufacturer's data plate on the furnace.
Mar 07, 2011 | Heating & Cooling
I have a Dayton gas wall heater, about 1982, and the thermostat is "worn out." The last 2 digits of the thermostat [Honeywell] serial number is also worn to the point of being illegible. The...
The only thing you can do is get the modol and serial number off the furnice it self go to your local parts store and thay will tell you if that part is available ore not,thay will be abel to tell you for sure.
Jan 20, 2011 | Dayton Gas Furnace Heater
I have 210k btu Magic Chef gas fired furnace and I need a model #
Replace the start capacitor. Take an amp draw on the motor when it starts. Compare that with the rating plate for FLA.
Nov 04, 2009 | Continental Heating & Cooling
Coleman gas furnace. Burner will re-fire for a few seconds during the cooldown. Model G8C07512MUB12A
This is a little complicated because it can be several things and you need to provide more specific info....It could be your furnace is shutting off on the High Limit...which means your furnace is running too hot...check the filter , return air vents etc would be an airflow problem...dirty blower....Furnace can be too big for your house....when the furnace shuts off on High LImit , the fan will continue to blow air , cooling it down as usual and once the furnace cools enough to reset the high limit trhe furnace will Ignite again as long as the thermostat is still calling for heat . The furnace could also be running too long and getting too hot....your Ductwork can be too small...many factors come into play
Oct 25, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
