Question about Pioneer Televison & Video
The screen on my Pioneer tv is stuck in an enlarged mode. The broadcasts don't fit the screen. This just happened. We have tried the screen fit button but no luck. Any ideas?
  • 1779 Answers
SOURCE: Freeze up
Most likely it's your memory ic (eprom). Sometimes depending on the make, an authorized service center can flash the eprom back to normal. This is something you can not do but I hope this helps a little.
Posted on Feb 22, 2008
  • 17130 Answers
SOURCE: I have a pioneer elite
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
Posted on May 19, 2011
  • 108 Answers
SOURCE: i have an akai 52,
Check for a button that says 'pic size' or 'zoom' or 'aspect' or something similar on your remote. Most newer TV's have this funvtion but it's almost always controlled by the remote, not the TV menus.
Posted on Sep 17, 2011
  • 6 Answers
SOURCE: my protron tv is stuck in picture in picture
push the pip button and it will go away
Posted on Feb 25, 2013
  • 40498 Answers
SOURCE: how to enlarge screen to full size when old movie is broadcast.
Old movies may be broadcast in old formats and would be distorted if enlarged.
Posted on May 21, 2016
How to enlarge screen to full size when old movie is broadcast.
May 21, 2016 | Hitachi Televison & Video
My Pioneer PDP508XDA tv is stuck in standby mode since a power outage
try unplugging and then hold the ower button in untill all lights go out. plug back in and try to power on.
Apr 13, 2014 | Office Equipment & Supplies
The score on football games on fox and cbs are halfway off the screen. How do I fix this?
It is likely that you have the "picture size" set to a mode that does not match what the channel is actually providing.
Go to the Menu options on your TV and then look for the Picture options. Change the size between the different options (typically 16:9, 4:3, Wide, Fit to Screen, etc.) and see which mode works best for the Fox and CBS broadcasts.
It is likely you have the TV set to Wide or Fit to Screen. Both change the settings to make 4:3 broadcasts fill the screen of a wide screen TV. Changing this to 16:9 should allow you to see the information on the sides and bottom of the screen again.
Nov 03, 2013 | Insignia IS-LCDTV32 32 in. Television
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I lost my remote, and the picture is smaller than the actual screen by about 2-3- inches on all sides. how do i enlarge the picture to fit the screen?
This function u can't do it without the tv original remote.Try website like to buy the tv original remote.Than used one of those buttons on the tv remote like View Modes,Picture Sizes,Aspect Ratio,Zooming to do the adjustment for tv screen pictures sizes.
Jun 23, 2011 | Philips 32PFL5403D/27 32 in. LCD TV
Top and bottom of screen are cut off how do we adjust to get screen to fit
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Mar 07, 2011 | Panasonic PT-53WX54 53" Rear Projection...
Loss of picture on Pioneer Plasma Tv
i have a pioneer 43 inch bought in 06. tv wont turn on light flashes red the light means standby. what does this mean
Jun 07, 2009 | Televison & Video
Viewing mode will only go from zoom to wide!!!! please help
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
May 29, 2008 | Samsung Televison & Video
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
