Question about Sewing Machines
How to insert hook cover and bobbin case for Aldi Lumina sewing machine
  • 6 Answers
SOURCE: Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Posted on Dec 30, 2007
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
SOURCE: bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Posted on Aug 07, 2008
  • 51 Answers
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Posted on Sep 06, 2009
  • 108 Answers
SOURCE: JcPenney 7064 , bobbin case, bobbin and manual ??
i was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
Singer 328 is not stiching
if upper thread correct, check bobbin is wound and inserted correctly. Pulling bobbin thread, the bobbin should turn counter clockwise. make sure thread is under bobbin case tension spring. With cover plate open hold needle thread and turn hand wheel towards you to see if hook picks up needle thread and passes it around bobbin case. if not check hook timing
Jan 05, 2014 | Sewing Machines
I have a hyundai 8 stitch sewign machine been working brillant but last night it kept missing the tread and the thread breaking or jabbing . today looking at it i see when it jabs the Bobbin Case Inner...
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
if the sewing machine has a top loading bobbin, you may have to have the sewing machine checked to see if there is something wrong with the bobbin case or the hook and hook race.
I suggest try a new needle--one for the fabric being sewed
also try another bobbin
rethread the sewing machine top and bobbin, using every thread guide.
Aug 21, 2013 | Sewing Machines
The bobbin on my Brother Xr 34 sewing machine won't catch Please help
try changing the needle
try a different bobbin
try turning the bobbin the opposite direction
make sure the bobbin is inserted correctly into the bobbin case
there could be something wrong with the hook and hook race
and the machine may need some adjustment
Mar 06, 2013 | Sewing Machines
Where to oil my singer 2263 ?
The 2263 only needs oil on the hook race (below the bobbin case). The complete cleaning procedure for this area is, with the needle fully up, remove the bobbin case and rotate the arms that hold the hook outwards. Remove the hook cover and the hook. Wipe the area under the hook cover and hook with a soft cloth. Put 1-2 drops of sewing machine oil just to the right of the center of this area. Rotate the hand wheel until the hook race is on the left side of the bobbin area. Then replace the hook and hook cover. Snap the arms back towards the center and insert the bobbin in the bobbin case.
With the bobbin out and the needle up, you should also unscrew the faceplate and wipe the feed dogs with your machine brush. (For best results, clean this before you oil. If you do not do this first, you may brush lint and bits of thread into the hook race and risk jamming this part.)
For pictures, see http://www.singerco.com/uploads/download/1213_oiling-2263.pdf .
I hope this helps.
Dec 09, 2011 | Singer Sewing Machines
B/A 180 engine groans and then stops...push pedal and may start stitching again...Sometimes have to turn hand wheel. ????
Refer to your owner's manual to better assist you in following these instructions.Remove the bobbin case. Release the hook cover by pushing the lever which is located at the top left side of where the bobbin case is inserted. After the cover pops open, remove the hook. Observe if the machine now moves freely. Clean the hook and the hook area with a toothbrush, removing all lint and debris. Place one small drop of sewing machine oil on the rim of the hook. Replace the hook into the raceway and close the cover. Replace the bobbin case and test sew.
Jun 02, 2011 | Bernina Artista 180
How do I re-insert the bobbin case? It has
I assume this is a oscillating hook machine. I.e. the case snaps underneath the machine in front? Hold the flap of the bobbin case and push it firmly on the hook post as far as it will go. Make sure the "finger" of the bobbin case is at the top.
Jul 22, 2009 | Kenmore Sewing Machines
RACE AND HOOK NOT ASSEMBLED CORRECTLY IN MACHINE 534FB
Turn the hand wheel until the hook race ON YOUR MACHINE is in the left position ...insert your hook ( semi circular hook) to the right side( jagged edge to the bottom)...insert the hook race cover ( circular, with the two jagged points facing inwards and in 12 o'clock position) and snap back the two hook retaining arms. Ready for inserting bobbin case. Good Luck
Apr 30, 2009 | Singer 8280 Mechanical Sewing Machine
Machine is very loud and jumpy
Usually this problem occurs on machines with a front load bobbin case. If so, remove the bobbin case, the shuttle hook cover (two levers to the sides of the bobbin case area cover and shuttle hook (part the bobbin case goes on and it is ½ mooned shaped). Then clean and oil (with Q-tips and sewing machine oil NOT 3 n1 oil) the round outer area where the hook rides. No lint at all and squeaky clean. Then 3 drops of sewing machine oil in rounded groove where the shuttle hook rides. Then replace the pieces:
Replace hook:
Identify the the hook driver (still in machine), it is 1/2 moon shape. The hook is also 1/2 moon shape. If you lay the machine on its back,( it's easier). Set the hook 1/2 into the other 1/2 of the hook driver to make a circle. Then put the hook cover on (machine still on its back) with the tabs for the twist locks pointed to you. Needle gaurd on hook cover to the top of the machine. Snap the twist locks in place, replace the bobbin case and viola!
Mar 20, 2009 | Simplicity Denim Star SW210
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Where does the oil go?
To oil machine.....Remove the bobbin case.Snap the two retaining arms outwards.Remove the hook race cover (circular ring ) and the hook ( half semi circular) and clean with a soft cloth.Lubricate right hand side wall ( 1-2 drops of oil) turn hand wheel a few times until the hook race is in the left position...replace hook..replace hook race cover ( smooth end to the bottom) and snap back the two hook retaining arms and insert bobbin case and bobbin.
Jan 06, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
