Question about Pool & Spa
What causes my kozi 100 pellet stove fan to come on and then go right off and then do it again
3 Suggested Answers
SOURCE: Honda EU30001 generator causes erratic pellet stove operation.
Ok Motors and the like generally DO NOT really go all that well from a generator, what load does the Stove use?, You must add up the cumlitive "Wattages" of ALL things connected, see your generator is about 3000 Watts, 3KW, How much "headroom" is there between the two? Whats supplied versus whats being used? Purely inductive loads, like Motors etc, are less responsive than electronic loads. I suspect that your generator is NOT providing enough current to the Stove, especially when "Other" things are connected. also. Look, if the, any, generator is 3000 Watts really you should only load it up to a couple of KW's, 2.5KW being about maximum. To do what you are doing would require, IMHO, at least, 5KW, to get the "Headroom" of current drawn over current able to be delivered by the generator. Also inductive loads loose heaps of power and actually cause a higher draw. So that your answer, you must use it well, inside it's rating, not right up to the limit.
Posted on Feb 26, 2010
  • 27 Answers
SOURCE: I have a Kozi Bay
clean the jets
Posted on Apr 20, 2011
Testimonial: "Thanks for your helpful hints..."
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
Kozi pellet stove wont lite keeps blowing fuse
If your Kozi pellet stove has an igniter (located in a steel tube under the fire pot), check to make sure the igniter isn't shorted out (dead short).
I recently purchased a used Kozi 100XL that had an igniter that was bad. I also found that, prior to me buying the stove, the old igniter had been twisted inside its steel tube under the fire pot bringing its two wires at the end of the igniter together. These touching wires likely were throwing circuit breakers for the previous owner of the stove but, by the time I bought the unit, this had resulted in a burned wire at the fan thermal switch where one of the igniter wires connects. After repairing the burned wire, I plugged the stove back in and a house circuit breaker was thrown. A new igniter repaired the problem.
BTW, Kozi has a better than excellent online customer service who will likely walk you through any problems with your stove. They did for me even though they knew my stove had been purchased used.
Jan 28, 2014 | Pool & Spa
Our napoleon stove barely heats the room it is in and it is new first year used,,
Try this....before starting the stove, place a handful of pellets into the burn pot. Start stove with feed rate about 2-3. Let the pellets ignite fully, then turn pellet rate to about 5, less then max. Let a good flame develop for 5 minutes or so, then turn on the fan. I set the fan at about 3-4 as advised by the tech. Reduce feed rate to about 4. I keep my damper on 2 1/2 to 3 to supply air intake. Napoleon is not the greatest stove, and I'm having an issue with mine after 3 years, but hopefully this helps. It will never give the heat of a wood stove, but get a strong fire going first, then tune it down after the room gets warm.
Jan 16, 2011 | Napoleon Auburn Pellet Stove Heater
Feb 26, 2010 | Honda 6370C - Parallel Power Kit For ...
We have a pellet stove -seems to be working ok except that we have a smell of smoke like that of having a fireplace. We think everything is sealed correctly. Any suggestions?
From what I have read on these things, never had one, but they have 2 fans, maybe one, plus an auger and thermostat. The one fan would **** fresh air in from the room to fuel the fire, while the other fan would blow the heat back out from a sealed area. The auger spins constantly, slow, dropping pellets on the fire determined by the thermostat. If this is right and relates to your stove, I can see where the smell of smoke would come from. The second fan is pulling in smoke from the fire. Check the gaskets in that area. I was wondering if it wasn't just the new stove smell you were getting?
Feb 23, 2010 | Napoleon Auburn Pellet Stove Heater
The kozy wold heating stove flame has irruglar
kozy world KW112, 1 burner is dim flame 2nd flame is bright red. What is the problem?
Dec 09, 2009 | The Companion Group Kozy World Portable...
5510 king pellet stove exhaust problem?
Mine does the same thing too-what I do is shut it off and put it on again then it works fine.
Nov 22, 2009 | Napoleon Auburn Pellet Stove Heater
Pool & Spa Logo
59 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
