Question about Watches
How does one set the day on a Kings & Queens Automatic 55mm watch ??
I cant get the arms to automatically set themselves
About Self-Winding Automatic Watches - Self-Defense Armory
about mechanical watches, self-winding, automatic watches. ... Secondly, and this is where it gets a little hazier, people buy automatics for reasons that cannot be clearly ... Self-winding automatic watches depend on the movement of the arm to ... Avoidsetting the day and/or date (if your watch has these functions) at night.
About watch movements: technical details
Dec 26, 2015 | Casio GA-110-1B GA110 G-Shock Alarm World...
My timex watch changes the date at noon instead of midnight. How do I fix this?
This is because you have reversed am with pm.
Set your watch 12 hours back and the problem should be solved.
You might want to wait till midnight or noon to check it's fine.
Note: if you see the day shows the previous day rather than the present day, you have to set the clock 24h ahead.
Problem solved!
Mar 02, 2011 | Timex Automatic Watch
mcdevito75 here, I would imagine your Rolex is an automatic, not all Rolexes are. After 2 days not running at all your Rolex needs a very good start not just putting it on and that"s it. Sorry to say!, I would ask you to do this, With your watch close to your ear I would like you to wind the watch, listen closely, if you haer a clicking or a drag sound you know you have to give about 20 winds to your watch before you put it on, after the 20 winds the automatic takes over. If the stem just spins and no sound, Click or drag, then your rolex is fully automatic, after you put it on you"ll have to ttwist your wrist back and forth to get the automatic moveing to wind your watch somewhat. Twist your wrist back and forth maybe 20--30 times, this way your watch has an initial wind and as you wear it the winding continues with the motion of your wrist, after it"s wound pretty good if it stops and goes, have the watch serviced.
Jul 01, 2010 | Rolex Day-Date President 118238 Wristwatch
Bucherer Day/Date Setting Problem
You have to change day by the means of moving hands clockwise. Move as long as the desired day appears in window, then adjust the date and set time. Rate me, plz.
Mar 31, 2010 | Watches
How can I recieve a manual for my Gevril Chelsea?
hi i have a Gevril automatic watch and it said in the manual never try setting the watch between 21:00 - 04:00 , that would damage the internal parts
Nov 25, 2009 | Gevril 18K Chelsea Swiss Automatic...
I have an automatic watch that shows the day of the week, I can't set it so that it changes from day to day correctly. I've changed it to correct day right after midnight and by the end of the day, it's...
first you kepp the day and date set yesterday's , for example today is 31st and monday so you set 30th and sunday , now keep rolling time by key till day and date has complitaly changed,remind that do not roll anty clock, it may be damages to your watch,now when you get change day and date its a midnight of 31st and monday, now set the time and get started ,
Aug 30, 2009 | Invicta Corduba Leather 3809 Watch for...
Tag Heuer - Aquaracer automatic (Day/ Date)
Actually in the realm of things that is close to midnight. But if you want this changed you will have to take it to a watch repair person because the movement will have to be taken out of the watch and the hands pulled and rest to change when the calender flips over. When I set up watches i usually have the day/date flip after 2 am so that most people never see it change ( because they are asleep lol)
Jul 31, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Nicolet Men's Metrosphere Swiss Automatic Stainless Steel Watch the day is not in English, currently it shows MIE, can I set this to show the days in english?
I don't know this watch specifically but typically the following applies:
To set the day/date you set the crown (winder) to the first position (second posn is "set hands) i.e. pull out one stop, and rotate winder eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
Jul 17, 2009 | Watches
Setting my day date on watch
mcdevito75 here, The stem has 2 positions, first, set the day to 1 day before the day you need, now, slip a finger nail just under the stem and gently, gently lift the crown to it;s first position, set the DATe to 1 date before the date you need. Push crown back in, now pull crown out to set the date and time of day. Your watch is set and should change around mid nite
May 03, 2008 | Seiko SLL003 Wrist Watch
Operating instructions for a replica Rolex oyster perpetual cosmograph daytona watch
I need to know if this watch is an automatic or quartz (battery-operated) watch. For either watch, your crown screws in clockwise- which, by the way, is on the right hand side of your watch, and looks like a miniature doorknob. Unscrew it COUNTERCLOCKWISE, then, if your watch has a date on the dial (face of watch), your crown will pull out in two different positions. The first position is for your day/date. Forward will either do the day or date and backwards will do the other. DO NOT SET YOUR WATCH BETWEEN 10 O'CLOCK AND 2 O'CLOCK, because it can ruin your watch. The second position (pull out completely) is for setting the time. Go around until the day and date changes so you're sure that you're on a.m. or p.m. and then set accordingly. Push the stem all the way back in - this is your winding mode if you have an automatic. Wind 50 times before use, or else it won't run correctly. Now, push the stem back in (it's spring-loaded), and turn it counterclockwise to seat the tap, then clockwise until it's completely screwed in.
Apr 22, 2008 | Watches
Watches Logo
18 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
