A larger picture of remote so I can read it - Televison & Video
  • kakima Dec 17, 2016
    Hi margaret ferreira, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
I have somehow made the picture larger and i lose part of the screen. I have a lg 42 in. I dont have a model # but the number on remote ismkj0653801. Please help
get the on screen menu up and change the aspect ratio to adjust the picture size
use the remote to adjust pixel or aspect ratio
Dec 12, 2017 | LG Televison & Video
How do i adjust the picture to fit thescreen on my toshiba flat screen tv
Hi, T
There will be a key on the remote control to adjust the picture size. You can adjust the picture size of your choice using this key.
Oct 11, 2014 | Toshiba Televison & Video
Picture size
from remot press menu > picture menu> contrast> 9735 then service code wil open u can select & adjust
Apr 26, 2013 | TCL LE32HDF3300 32 Inch LED LCD HDTV
The image is larger than the screen so the heads are cut off
try changing the video aspect ratio to something smaller. Also you may have accidentally pressed the zoom picture on the remote. There should be a button on the remote to change it back to normal. Also you can change it back by going to the menu and picture and it should be one of the options.
May 28, 2011 | LG Televison & Video
Son got a hold of the remote and now the picture is larger and doesn't fit the screen- I don't know how to get it back to normal. Help!
your tvs zoom function is in on position. to make it of just press the picture size button on your tvs remote. every time press the picture size button different mode will seected, like zoom ,compression ,normal.
select the normal mode.
be sure that the selector switch in the side of the remote should be at TV
Jan 27, 2011 | Toshiba 32HF73 32" TV
My picture is larger than the screen. How do I get the picture to match the screen? ---Dave---
Look for a buttons in ur remote like Aspect Ratio,VIEWMODE,P.size push and used one of these buttons on the remote,will be able pick the picture sizes that will fit ur tv screen frame.
Dec 03, 2010 | LG Televison & Video
How do i reduce the picture size on a LG 48 it was changed and now i cannot read the kyrons, the picture is larger that the TV [make sense?] thank you
Look for the button on ur remote,that said VIEW MODE or P.SIZE.Push one of those button either one on ur tv remote.Than pick the size of the picture,that fit ur screen.
Oct 12, 2010 | LG Televison & Video
The picture is larger then the screen and we can't see the full picture
Check the Aspect or Picture size settings on your Sanyo remote control and/or your HD cable box.
Mar 02, 2010 | Sanyo DP50747 50 in. Plasma TV
Unable to operate remote of Pandigital picture frame
remove the memory card and see if the remote works wit hthe built in memory pics. if it doesnt pic up your card you will just have to try another card. The frames dont read cards larger than 1 Gb very well either - reguardless of how many pics are on the card.
Dec 03, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
Picture issue
you may want to try to reconverge the picture there should be a control button on your remote to readjust the picture
Aug 29, 2008 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
