Question about Amana Refrigerators
How to shut off icemaker Amana side by side - Amana Refrigerators
5 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
Posted on May 26, 2009
  • 93 Answers
SOURCE: Amana side by side icemaker stopped working
The icemaker is not working because the water pressure is too low. An icemaker is controlled by a timer so it has no idea how much water is in it. The water valve gets energized for about 7 seconds letting water in the icemaker, but if there is no water pressure then the icemaker will not fill.
Posted on Sep 12, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Amana side by side ice maker quit. verified water
Hi andy and wlecome to Fixya. There is usually a semi white plastic line that runs up the back of your refrigerator. Here are some steps you can do to verify that the water valve is actually working
You will need an old power cord or cheap extension cord with 2 female bayonet terminals on it. (Make one if you have to.)
1. Unplug the unit.
2. gain access to the water valve and disconnect the wire terminals 2 ea from the solenoid.
3. Connect the cord you made to the solenoid making sure that the 2 terminal connections will not come off or touch together.
4. Get a bucket and gently pull the plastic line from the bulkhead connector in the upper area of the back of your unit and place it in a bucket.
5. Plug the cord into the wall outlet and HOPE that water flows into the bucket.
If the water does NOT flow then the water valve is clogged and will need cleaned or replaced. Many of these water valves have a hose type inlet connector fitting from the water SOURCE. Before attempting to remove any water lines turn the water source OFF. That fitting can be removed and you can check for a clogged screen.
Just remember to remove your test cord and re-connect the chassis harness to the solenoid when your done. Also put the plastic line on the back of the unit back into the bulkhead connector.
If you have water flow thru the line then the bulkhead connector fitting to the icemaker is froze up and you can thaw that out with a hair dryer (quickly) or a fan (Slower) with the unit unplugged.
This should give you some direction on what to do. Best of luck!
Posted on Jan 25, 2010
  • 8 Answers
SOURCE: I have an Amana Side by Side Refrigerator with an icemaker and water dispenser. I don't have a water line to hook up to the refrigerator. Is there an on/off switch for the icemaker?
There should be a stop control near the icemaker where it collects ice in the tray. It should be an L-shaped lever. move it to the stop position.
Posted on Oct 03, 2012
Oct 02, 2012 | Amana Refrigerators
Icemaker does not shut off even when arm is up.
arm must be disengaged inside ice maker or the smal switch in ice maker
Aug 02, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Have an amana side by side refridge. freezer will not shut off
bad thermostat
it is up behind the controls
make sure the other side is clear
its behind a plastic dome on the right hand side of the freezer, upper next to ice machine....
take off the cove and make sure there is not ice in there...
if not its proibably bad and should be replaced
Oct 01, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Sep 12, 2009 | Refrigerators
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
SCD25TW Amana 1998
the fuse for the i/m is actually in the wiring harness that plugs into the icemaker. if the model is correct the icemaker goes across the back of the freezer. when you installed the icemaker on one of the wires (i think red wire) there is a black "pill" looking thing. this is the fuse.
Feb 23, 2009 | Amana SXD524VW Side by Side Refrigerator
Water from chilled water dispenser on my amana side by smells bad and tastes bad
its either the icemaker itself or could be water actuator padle needs replacing.
Aug 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana scd23vw
attempt to pry off the plastic cover over the ice-maker (or look for screws). You should see at least one screw adjustment and clockwise turn is more water.
Jun 05, 2007 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
27 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
