My program is set for heat from 6:00am to 10 pm.. Furnace not running even tho set for 70, actual says 65. small message on screen next to temp "following schedule in recovery". How do I get heat?
  • Heating & Co... Master
  • 5,468 Answers
You will need to do additional trouble-shooting. This could be a faulty thermostat, a broken wire at the thermostat or a problem with the furnace. At the thermostat, check that the wires are fully seated at the terminals. Make sure that the conductors haven't broken. (I've seen the wires break after they weakened.) You can try placing a jumper between the terminals for heat and ground. (For a single-phase forced air system, the Rh wire calls for heat.) If your system has a C (common) wire, make sure that the voltage is getting back to the furnace. You can try a different thermostat.
Also look at the furnace. Some systems will have an LED indicating a problem with the unit. Gas systems can have a problem with the flame. Gas or electric forced air systems could have an issue with a blower. Heat pumps can freeze up if the temperature is below their operating range.
I hope this helps. Please add a comment with the manufacturer and type of furnace (oil, gas, steam boiler) that you have if you need more ideas for trouble-shooting.
(my own gas furnace went out on Wednesday and was temporarily fixed by resetting the thermostat and using a jumper across the appropriate terminals. The flame didn't come on at 6 A.M. when the thermostat called for heat. Today, the blower completely failed and needs to be replaced. The earlier failure is likely to be related to this failing blower motor. When I followed the manual's instructions for testing the system, I got a "needs service" code. However, the unit didn't display a trouble-code before I did that test.)
Posted on Dec 17, 2016
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80. Any...
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Feb 09, 2015 | Heating & Cooling
Fasdfas
Does the furnace stays off?.
Furnace are ment to cycle on and off because of limits .If you set to 70 furnace would cycle several times before reaching that temperature.
Just make sure your filters are clean and you got proper return air flow because lack of air flow will cause furnace to shut off sooner than normal
Jun 08, 2017 | Heating & Cooling
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Have gas furnace and this winter,began having
The Thermostat Wizard is an interactive tool that will guide you through wiring and troubleshooting your thermostat, as well as programming it to the most comfortable settings for you and your family. Simply answer the questions from the Thermostat Wizard to correctly connect, troubleshoot and/or program your Honeywell Thermostat. You can even print the instructions and bring them right to the thermostat to help make things easier.
Go to: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Support/Thermostat+Wizard/
However - the problem is probably not with your thermostat but with your furnace. It is most likely a dirty flame sensor - a maintenance issue. If you have not had your furnace serviced recently (more than 1 year) that is where you should start. Modern furnaces require regular maintenance.
Please rate my answer!
Feb 28, 2009 | Honeywell Electronic Programmable...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Honeywell Chronotherm III
Try this link:
http://yourhome.honeywell.com/yourhome/Applications/TechLit/TechLitSearchResults.aspx
It looks like there are a variety of model numbers for the Chronotherm III. Hopefully you can locate your model number.
Dec 17, 2007 | Honeywell Power Humidifier: Furnace...
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
