Question about Comfort Zone Heating & Cooling
Need help with a wire diagram for comfort zone heater CZQTv8 cant find where to take a photo to post
My comfort zone infrared heater wont work. It shows coFL
You did not post the model number but from the error message it could be the intake filter is dirty. They have a lifetime filter but it has to be cleaned occasionally
Nov 20, 2016 | Comfort Zone Heating & Cooling
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
Comfort Zone CZ 1500 A04 CONTINUES TO COME ON
The AO4 is a board used by Earthwise on the Comfort Zone Heater. The reading is the board being used. If the heater just gives that reading it may need to be reset. This can be done by pressing up, down and enter at the same time. If this does not work unplug and try it again. Hope this helps
May 04, 2011 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone heater wire element is glowing and smoking
dust and dirty air can be one problem or some object has fallen in to it you may need to get it cleaned
Nov 29, 2010 | Comfort Zone CZ792 Electric Utility Heater
Pool heater thermostat lights up but water do not get hot, need wiring diagram.model#C-SPA XI 11,240 volts 5.5kw or 240 volts 11kw
There should be a large, easy to read diagram under the cover once you remove it from the heater. Is the one under your missing or unreadable? Hayward doesn't publish one on their tech website or residential documents page so I have an email into our tech support contact asking for one in case yours is missing. If you find it under the cover please add a comment to that effect. FIXYA website has not been letting me post pictures lately so getting you the info may be a little difficult.
Dec 29, 2009 | Hayward Comfort Zone Electric Spa Heater...
Heating & Cooling Logo
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
