My monitor heater 2400 pops up a code e1 what does this mean
  • 61 Answers
SOURCE: monitor heater model 2400 is giving a e 15 trouble
The e15 code could also be a control board issue.
The power detector may have been damaged due to years of brownouts and surges.
Also, if you have added anything to the same circuit that the Monitor is plugged into; it is also possible that that is causing the low voltage code.
Unfortunately, it's hard to say without checking alot of different things.
If you have a place locally that services Monitors, it may be a good idea to take it in for service.
Sorry I can't be more help.
_Helping Hands Services_
- Fairbanks, Alaska -
Posted on Oct 30, 2009
  • 3 Answers
SOURCE: e13 code, monitor 2400
You have an obstruction in your fuel line. Lint or rust or some other debris, either in your main fuel filter which I hope you have or in the small one in the fuel sump on the lower right hand side (the little square hole below the round finger hole for the reset button). The screen is cleanable with air or brakekleen or both. Or it might be that your Constant Level Valve is tripping or has tripped. Push the button in the round hole on the lower right hand one time quickly (don't hold it down or press it several times slowly) and you should hear the float drop. Fuel should resume flowing to the fuel sump at that time.
Posted on Nov 03, 2009
tunde007
  • 2382 Answers
SOURCE: what does error 1 mean
Hi, you can view the error codes and how to troubleshoot them on this LINK
Posted on Oct 30, 2010
SOURCE: Monitor 2400 Kerosene heater service
Drain the air out of the supply line at the bulk tank shutoff valve; there should be a small hex plug for doing this. On the bottom right hand side of the heater is a round hole that allows access to a finger pump for the fuel; press this three times slowly. Heater should start!
Posted on Dec 14, 2010
  • 674 Answers
SOURCE: I have a monitor 2400 and it is flashing code E01
E01 means the flame rod is sensing a flame when there shouldn\'t be one. This is caused by a grounded flame rod or pinched wire. For some reason the flame rod could be touching metal inside the heater. The flame rod could be bent or the burner ring is warped so much that it is touching the flame rod. Another possibility is the wire for the flame rod has somehow gotten pinched. If you remove the front cover and the black grill from the heater, you can see the window into the burner. The plate it is attached to has about 10 screws holding it on. You can remove the plate using caution not to damage the gasket and look into the burner to see what is going on. The flame rod should be centered between the burner ring and the burner. Let me know what you find. If you need to order parts I can help you with that.
Niten\'s Heater Service on Facebook
Posted on Jan 17, 2011
Testimonial: "I will check that out...thankyou"
Monitor heater 2400 turned off with code E13, what does that mean?
This is an over heated indicator, what make and model unit.
Apr 04, 2015 | Heating & Cooling
Repair manual for a Monitor 2400 kerosene heater system
I just bought a use Monitor 2400,it will run and then start to beep,has E 14 on it, What does that mean? Don't have the manual for it.
Feb 02, 2012 | Heating & Cooling
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
I'm getting an "E 13" code on my Monitor 2400; what does that mean? I don't have a manual to tell me.
E 13 means ignition failure. You can see a list of error codes at www.monitorproducts.com. What happens when you try to light the heater? You can contact me at nitensheaterservice@embarqmail.com.
Jan 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Monitor heater model 2400 is giving a e 15 trouble code what does this mean ??? found that may have to do with low voltage but nothing has changed and it has worked fine for years ????????
Oct 28, 2009 | Heating & Cooling
E13 code, monitor 2400
Dec 21, 2008 | Heating & Cooling
Dryer turns off and shoes e1 code
E1- Thermistor open.
It monitors the exhaust temperature, and cycles the heater relay on and off to maintain the desired temperature.
It could be the sensor, or electronics.
May 08, 2008 | Whirlpool GGW9200L Gas Dryer
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
