Question about Kenmore Kitchen Ranges
I have a new Kenmore gas range 790.73032313. stove burners work the oven won't turn on. Pilot not glowing. What does the warranty cover? Is there a reset I can do?
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
aborcass
  • 2651 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
bad oven ignitor is the most common cause of bake failure, located onthe side of hte burner bar itself, if youd like with a multi-meter, you can check the wires leading to the ignitor for 110v. if you have power and nothing was glowing from ignitor theres your problem
Posted on Nov 23, 2008
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
ZJLimited
  • 17970 Answers
SOURCE: my Kenmore Elite Gas Range
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Posted on Jul 18, 2011
rbheaton360
SOURCE: Kenmore Range/oven Burners won't lite
Anyone know how to remove the cavity of a kenmore elite range? it expanded during the self cleaning and now it's to big for the racks.
Posted on Nov 07, 2013
Need to turn gas pilot on
Stove in ? has electronic pilot so there is nothing to turn on
top burners should have spark and oven has a glow
if the burners not lite do you here a clicking sound no clicking spark box is bad
oven not lite need glow
price of glow $40 price of spark box $60
Nov 02, 2014 | Hotpoint Kitchen Ranges
Gas stove top works, broiler works, oven does not
is it electronic iginition? are you asking about top burner pilots? if so there are under the top in the middle beteen each side of the burners 1 pilot does burners on right and 1 on left. oven pilots are underneath you have to remove bottom door look in there at back and look up and you'll see it. if its a electronis ignition range you have no pilots!! glow coils and sparkers....
Feb 06, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
I have a kenmore stove 362.7361193 pilot not on
There isn't a pilot light on MOST modern gas ranges. The top burners are controlled by individual igniters through a common spark module. The oven, however, is controlled by an igniter on each manifold. One for bake, one for broil. If you are having problems with ONE of the oven features, I would suspect a bad igniter. If BOTH oven features are bad, you may have a bad Electronic Oven Control (EOC) board. If the oven works, but none of the surface burners are working, I would suspect a bad spark module. The following link explains a little theory on oven igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Since your range appears to have a common gas safety valve and regulator, all burners are fed fromthe same gas source. Which means, if you have ANY burners lighting, you probably don't have a gas problem.
I hope you can determine what your problem is from the information I provided. If not, please post back and elaborate a bit more on your symptoms so that I may assist you better. I hope this helps you.
Jul 21, 2009 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Apr 25, 2009 | Ovens
Kenmore gas range model # 362.7121191 oven
Could be the thermostat, glow bar, valve or wiring but usually the glow bar
Feb 22, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My oven doesn't work but the burners do, what's up with that?
I was looking for a solution to my problem. In reading the comments, I can probably provide more information than is given here. My Kenmore gas oven won't ignite. I have over 25 years as an electronics techincian so I am very aware of lethal voltages. I unplugged my stove, it is a 120 volt model. After pulling the panel off so I could get to the thermostat which is the piece the knob goes on, I plugged the stove in and checked to make sure I have 120VAC to the thermostat. I have a red wire which has 120Vac, the thermostat probe wires, and a yellow wire which goes down to the back of the oven.
My red wire had 120Vac. I then unplugged the stove, very important at this point, and meaured with an ohmmeter across the yellow and red wires. When the oven is in the off position this is open. When I turn the oven on it is shorted. That should confirm the thermostat switch works. The next thing that has to happen is the glow bar/igniter has to glow. This is like all gas appliances, it has to glow to heat the gas valve and turn the gas on. My igniter doesn't glow so I ordered a new igniter. If your glow bar glows, it could still be the glow bar/igniter or the gas valve is not allowing gas to flow even after it is heated up.
If anyone sees a problem with this procedure, please let me know.
Nov 19, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
