Question about Sony Audio Players & Recorders
I need a owners manual for a sony str da800 a/v receiver
SOURCE: Sony STR DG 510 receiver manual
Hey there, found it on the sony site...
http://esupport.sony.com/CA/perl/model-documents.pl?mdl=STRDG510
Hope that helps.
Posted on Oct 19, 2007
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
SOURCE: left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Posted on Jan 22, 2009
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
dunnbiker
  • 8546 Answers
SOURCE: Can't get subwoofer working with sony model STR-DE845 receiver
read the manual
http://www.retrevo.com/support/Sony-STR-DE845-Receivers-manual/id/387ci973/t/2/
First, it must be a self-powered subwoofer, then you've got some settings to select in the receiver.
Posted on Jan 21, 2011
How do I adjust the treble and bass on sony str-dh520?
See EQ Mode on page 59 of the owners manual to set the bass and treble for the front speakers, presumably for 2 channel mode. For multi-channel mode there are several pre-programmed audio modes listed starting on page 43 and music mode starting on page 44.
https://docs.sony.com/release/STRDH520.pdf
Mar 02, 2015 | Sony STR-DH520 A/V Receiver
Sony str d1090 owner manual
You should be able to get a free PDF on the Sony website.
Aug 21, 2011 | Sony STR-DE995 Receiver
NEED A USERS MANUAL FOR SONY RECIEVER STR D-1015 . I BOUGHT A USED RECIEVER WITHOUT A MANUAL AND CAN'T FIGURE OUT HOW IT WORKS
Please follow this link for a free download of your receiver manual:
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/STR-D1015-_E
Dec 17, 2009 | Sony Audio Players & Recorders
Sony STR-DE945-Component Set Up
billr, Go to http://www.retrevo.com/search?q=Sony+STR-DE845&terms=review+manual You should have a pdf of the 845/945 manual waiting!
Mar 11, 2007 | Sony STR-DE945 Receiver
26 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
