Question about Humidifiers
Vs 205 no mist replaced cartridge still no mist
2 Suggested Answers
SOURCE: venta 205 no mist
Check to make sure the float isn't getting stuck . The flashing light means it is out of water. There is a small screw, that you remove and check the float to make sure it slides freely.
Posted on Mar 24, 2015
My Sharper Image cool mist humidifier is not putting out any mist. I am wondering if it needs something cleaned or replaced and, if so, what needs to be done.
If this unit is an ultrasonic mist device, the mist element could be defective. They should be quiet, but still purr along and provide ma mist. The best bet it to contact the manufacturer and if under warranty, replace the system.
Jan 12, 2018 | Sharper Image Humidifiers
Venta Sonic VS205 Humidifier turns and has the green light, makes a buzzing sound, but no mist is coming out.
If you see mist in unit and not coming out fan motor in base of unit bad. Four screws in base and fan unplugs
Aug 20, 2011 | Venta Airwasher VS 207 3.7 Gallon...
No more steam. Want advice on disassembly.
There is info on the FAQs from Air-o-Swiss:
Q: No mist / unit is not working / empty indicator keeps flashing
A: Fill up the water tank. Check if water is flowing through the demineralization cartridge (attached to the water tank cap). If the water tank is full but there is only little water in the base it indicates that the water is now flowing through the demineralization cartridge.
  • Wait for 15 minutes to allow the mist to come out of the unit.
  • If the unit is not working and the empty light is not flashing you might have set the desired humidity too low and the current humidity level in the room is higher. That is why the unit switches off automatically.
  • If the empty indicator continues flashing and the tank is full, water is not flowing through the cartridge. Exchange the cartridge or the granules in the cartridge after 2-3 months, in areas with hard water exchange the cartridge after 1 -2 months. However, the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit does not reach its full performance.
If the granules are new, see the following instructions:
  • Make sure the cartridge and/or granules were soaked for 24 hours, water takes longer to filter through dry granules in cartridge and into the base. Next, remove 2 tablespoons of granules from the cartridge, and throw them away. Too many granules in the cartridge it does not allow water to flow from the tank to the base.
Q: Unit is running intermittently.
A: How long has it been since the contents of the cartridge were replaced? If 2-3 months have passed, it is time to replace the contents of the cartridge. However the demineralization cartridge and or the granules must be exchanged at the latest after 6 months or the unit ceases operating at its full performance. If the contents of the cartridge were just replaced there are probably too many granules in the cartridge. Remove 2 tablespoons of granules from the cartridge.
Feb 20, 2010 | Air-O-Swiss U7142 Humidifier
Venta 205 no mist
Throw the unit out - it's garbage
Nov 10, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Humidifier not working
Ensure there is water in the tank.
  • This may be caused by mineral deposits in the water channels. Try the following: Clean the water tank, base and vapor nozzel with a damp cloth to remove any build up in the water channel.
  • When was the last time the cartridge was changed. (If it’s been over 3 months, this could be the reason why the unit is not working properly.)
  • Unscrew the demineralization cartridge and run the unit, if it starts to mist then you need a new cartridge. (insert cartridge link here)
  • The screw cap for the water tank, onto which one first screws in the demineralization cartridge, has a small rubber gasket. make sure that gasket is not too far down against the outer screw cap. If it is the spring loaded button would not work properly to let the water descend into the base tank .
    The solution: push up on that small rubber gasket so that it is as far up and away from the screw cap as it can be without falling off, and voila! you get mist!!
  • If you have changed the filter recently then take out the cartridge and run the unit without the cartridge for about 15 to 20 minutes.
May 18, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Venta humidifier is not humidifying much.
Buy a new filter cartridge.
Mar 16, 2009 | Venta Airwasher VS 207 3.7 Gallon...
Air-o-swiss 7135 humidifier not misting
Ours has done the same thing after only 2 weeks. From article research, it appears that this occurs to everyone after cleaning it with the EZ Cal that is recommended. From looking at our unit and figuring out how it works, it appears as though the Ultrasonic Vibration membrane has stopped working. This particular piece is responsible for vibrating the water and making water mist particles which are blown out with the air. We will be calling the manufacturer on Monday to register a complaint and request a replacement unit.
Nov 23, 2008 | Air-O-Swiss 7133 Humidifier
No mist
The demineralzation cartaridge seems to be the issue. Remove it and see it the misting starts. If it does put a hole in the center cylinderical support of the demineralzation cartaridge, the one that fits over the white positioning post that is built into the base of the humidifier. This will allow the cartirdge to sink to the bottom and not interfer with the water tank plunger opening up and filling the base.I opened the hole completly but I think a smaller hole will do.
Dec 25, 2007 | Honeywell HUT-102 1.2 Gallon Humidifier
Noisy ultrasonic humidifire
The grey circle (diaphram) needs replacing. Try Maplin electronics.
Mar 31, 2007 | Swiss Air-O- 7135 Warm Mist Antimicrobial...
Humidifiers Logo
51 people viewed this question
Top Humidifiers Experts
Paul Carew
Are you a Humidifier Expert? Answer questions, earn points and help others
