Question about Exercise & Fitness
Track enduro 450 does not start. power light on but nothing else works
  • 6,694 Answers
If you wish to get some details about treadmill repair ; check the site linked here. Pull up older posts.
Posted on Dec 17, 2016
Is there a manual out for ktm 450 exc-r 2009?
Thank you for contacting FixYa with your inquiry.
Yes you can both download and obtain parts/repair manual, and the owners manuals for this bike.
A very excellent source of parts information are the fiche located at the following site: Drill down to either the chassis or engine as pertains to your issue. 2008 > ENDURO > 450 EXC-R > ENGINE
You can purchase Service/Repair Manuals from this site:
If it's the owners manual your looking for then this site will be helpful go to KTM's Home page.
Let us know if we can provide further assistance.
Jul 17, 2011 | 2008 KTM 450 EXC-R
Can you make this bike street legal?
Yes you can. You will need to add a headlight, taillight, turn signals, and change the tires to street tread instead of knobby tires. Then you would need to get a license plate from your local Department of Motor Vehicles. It might be cheaper to just sell the YZ450 and buy a 2004 Yamaha WR 450 enduro. This motorcycle is ready to ride on the street and the dirt. Click on the link below to view the WR450:
Feb 21, 2011 | 2004 Yamaha YZ 450 F
2006 vw jetta TDI- No power on drivers door. 2006 vw jetta TDI- No power on drivers door. Nothing works power windows, door locks, gas door release, alarm nothing
I might have the solution for your problem. I paid $1,700 to learn it.
I might start a class action against VW
Please call me at 450-346-2617
Dec 18, 2010 | 2006 Volkswagen Jetta
Oil type?
probably 30 weight
Apr 28, 2010 | 2007 ATK 450 Enduro
Stock suspension settings for a 2005 yz 250Need a baseline to start adjusting 195 vet novice Just need the clickers front and rear thanks
my 450 manual has different settings for EU USA an AUS out of 20 clicks between 10-14 out. so the best place to start is count the maximum clicks, and start in the middle, move a couple of clicks at a time and keep notes as its easy to forget. seat should compress about 80-100mm when you sit on it, but will depend on preference,track,mx, enduro etc try and get original manual from last owner
Apr 08, 2010 | Yamaha YZ 250 Motorcycles
Gas gas 450 fse 2005 lcd spedo turning off when cold outside
I have encountered this on more than one occasion. My experience has been a solder joint on the internal circuit board that is non conducive to cold weather. It has something to do with shrinkage on the board. Although I have only been able to track the exact problem one time, (a small crack in the panel board), all other times I have had to replace the actual unit.
Dec 15, 2008 | 2006 Gas Gas EC 450 FSE
Starter spining
I would try to start it again and all I get is a spinning and whining sound from the starter. It is as if the starter is not engaging somehow. A while after it cools down the bike will start agian. Does anyone have any possible answers. Thanks in advance!A lot of the starters are designed so the bendix shaft shears if it sticks to the fly wheel or over torques. If you remove the starter, connect a pair of vice-grips to the bendix gear. Jump the starter with a pair of cables, to get it to activate. The bendix will probably kick out, but not rotate. You should hear the armeture spin. Otherwise, the bendix will kick out, and you'll hear the armeture hum. If that's the case, check to make sure the fly wheel has been ground down, on the side facing the starter. However, you would probably hear grinding not spinning, if that were the problem.,,,
Nov 10, 2008 | 2007 ATK 450 Enduro
Clunking nois
there is a loud non-rythmic crunching/clunking noise. I suspected it would be either the clutch or transmission but I removed the oilpan and visually checked the transmission and oil pump and have completely disassembled the clutch, and none of these areas has any signs of malfunction. I also checked the chain/sprockets and nothing seems to be wrong there. Any ideas? The problem arose after a 600 mile road trip I took, which was the first long trip I had taken on the bike. I had used it for commuting for a few months prior to that. The first to second gear shift had gotten progressively more rough, to the point that sometimes it would not shift until I tried several times. I figured the transmission was having problems (this was my first bike so I had to learn now to use a clutch and not shift roughly), but it passed my visual inspection. The noise sounds as though there is a lose part that is getting tossed around inside the engine by a part that rotates with the engine rpm''s. If anybody has any ideas I would really appreciate it!,Cam Chain, Cam Bearings? Cam chain tensioner? these are likely suspects.,,,
Nov 10, 2008 | 2004 ATK 450 Enduro
Exercise & Fitness Logo
48 people viewed this question
Top Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
