Question about Panasonic Microwave Ovens
I am trying to download manual for Panasonic Genius Prestige NN-SD987S , but getting nowhere
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: error code H-98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
Posted on Dec 02, 2008
fathitkf
  • 1871 Answers
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Apr 13, 2010
jsrock516
  • 5911 Answers
SOURCE: need copy of users' manual panasonic prestige
Go to managemylife.com and type in the model number you provided under the "Manuals" link. Your owner's manual is available in .pdf (Adobe) format that you can download or print for FREE. I hope you find this information helpful.
Posted on May 31, 2010
SOURCE: I cant find an operators
Hi Ash,
I have a manual.....my Oven has served me for many years but I now have a problem with the door. I live on the sunshine coast ...give me a hoy if you need it. email me twocool3@hotmail.com
Cherryl
Posted on Nov 01, 2010
Why does it stay on demo mode?
Once a unit is in demo or showroom mode, it will stay and not exit. It doesn't matter if it's unplugged or not. Look in user manual and see if it list how to exit. Good luck!
Jan 29, 2016 | Panasonic Genius Prestige NN-SE782S -...
Is there an on/off button for the turntable on the Panasonic NN SD997S microwave
If you don't see one on the control panel, then there probably isn't one.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 17, 2014 | Panasonic Genius Prestige Nnsd997s -...
Stove top light on Microwave will not shut off.
There's a relay in the microwave that is not working.
Oct 01, 2014 | Panasonic Genius Prestige Nn-Cd989s -...
Trying to locate door latch part but Panasonic website not recognizing NN model number.
You can order Panasonic parts from Encompass here http://tinyurl.com/7qy85y or you can call them toll-free at 866-779-5835.
Apr 28, 2013 | Microwave Ovens
Panasonic Dimension 4 Genius problem
An internal fuse may have blown or the magnetron may have failed
Apr 09, 2013 | Panasonic Genius Prestige Nnsd997s -...
I need a manual for my Genius by Panasonic...
Assuming the NN-T888S is the correct model, you can download it from this URL:
http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaEnterpriseSearchCmd?N=779832187&Ne=&No=0&Ntt=NN-T888S&Ntk=EnterpriseSearch&URL=vEnterpriseSearch&storeId=15001&cmTag=true
If that doesn't work, go to www.panasonic.com, click on 'support', search for your model number, and see if it will provide you with a link to download the manual.
Dec 30, 2008 | Panasonic NN-T888S Convection/Microwave...
Microwave Ovens Logo
69 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
