Small amount of paper in small rollers where paper comes thru just before landing on paper tray. Cannot get at it.
Joed911
  • 4338 Answers
SOURCE: HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 01, 2008
gbsoffice
  • 55 Answers
SOURCE: Keeps telling me to put paper in tray-tray is full
It sounds like it has lost how to detect the paper tray, this could be possibly the paper tray itself or the configuration on the machine its self, look on the tray and see if it has a paper configuration slide or a magnet on the side or front that is missing, or you will need to go into the menu configuration and choose the paper tray.
Good Luk
Posted on Jan 29, 2009
  • 190 Answers
SOURCE: Error says there is no paper in the paper tray when there is
i am very sorry sir the server connection dropped. sorry for the inconvenience hope you were answered by our other experts.
Posted on Apr 10, 2009
  • 685 Answers
SOURCE: paper jam
This video explains how to resolve a recurring paper jam on your product. It sounds like the rollers on the rear access door may not be working properly and are making jamming the paper as it starts to feed up into the printer? Check the rollers on your rear access door and see if they have some give in them and roll freely.
Posted on Aug 18, 2009
  • 13 Answers
SOURCE: FEEDING PROBLEMS FROM PAPER TRAY
  1. Remove left cover (where the USB connection is located);
  2. Remove big black gear with a spring on it (you may need to unscrew the PCB that partially covers it);
  3. There is a clutch that sticks to the rubber pad behind this gear. You may put a piece of scotch tape towards to a rubber pad, so the plastic from clutch mechanism would'n stick anymore. http://www.phillycopiers.com/fix/hl-2040-2070-fix.jpg
Oleg Andrukh IT Specialist PhillyCopiers.com 215 364 3774
Posted on Apr 15, 2010
Doesn't seem to grab the paper
Clean the rollers with some small amount of soap and water fan the paper. replace paper use a differ draw or tray replace the rollers and sep pads
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 06, 2014 | Konica Minolta magicolor 2500W Laser...
I am getting the error code 13.05.00 on an HP laserjet CP3505n printer. The manual says that it is a front door jam. The jam is occurring every other time I try to print a document. The document is being...
13.05.00 HP CP3505N
Problem Solve. Same error. Generally either a real or phanton jam from the paper tray or manual feed tray.
SOMETIMES the manual feed would work but always one corner on the paper turned down when printed.
Remove toner cartridges and bottom paper tray
Turn printer on its back. The black plastic flap (about 9" long) that hangs down a small amount (near the white main feed roller) had one end most likely the wrong side of the small metal rollers above it.
This flap should hang about vertical. One end of it is most likely the wrong side of the small mostly metal roller above it. Each End of this flap should be about mid way between the two smaller metal rollers.
WITH CARE take a timber skewer and carefully encourage this flap back so that both ends are in the correct place
Sep 02, 2010 | HP COLOR LASERJET CP 3505 N PRINTER
Pc load letter keeps showing up.
Most likely your paper tray feed roller is becoming worn or just dirty.
Remove the paper tray and lift up the front of the printer. On the left side in the port where the tray was you should see a half moon shaped rubber roller with what looks like tire tread on it. Look at the steel shaft that goes thru it. One the end is a small clip that is part of the roller. Lift up on the tab and pull the roller off the shaft. You can then scrub it with a cloth and some glass cleaner. To reinstall just snap it back on the way it came off and this should solve your issue. If you notice when you have the roller out that on one edge the tread is worn smooth then you may need to replace it.
Good Luck.
Nov 18, 2009 | HP LaserJet 4 plus Printer
Paper not feeding not catching on the wheels
-Remove the paper from the paper trays.
-Fan the stack of paper.
-Turn off your printer.
-Remove the power cable of the printer
-Lift the main tray, then remove foreign objects or debris.
-Remove the rear access(back door) cover from your printer, then check for foreign debris the remove it
-Clean the rollers of the printer using a lint-free cloth with small amount of water
-let the rollers dry
-Reinsert the rear access door (back door) cover
-Fan the paper and put it on your paper tray
-Plug the power cable., wait for the printer to initialize
-Do a test Print., If its still not feeding please download your latest Firmware at kodak.com/go/downloads
Now if all the troubleshooting did not solve the issue please call kodak for service and repair Toll Free 1 800 421 6699. GudlucK
Nov 03, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Paper not pulling thru in tray 2 creating a jam message
IF its pulling multiple pages its a seperation pad if its not pulling at all its the pick up rollers.
Mar 26, 2009 | HP LaserJet 4050n Printer
HP paper jam
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Paper not grabbing
There are two possible solutions for this problem.
Usually it is due to the pickup roller wearing or becoming contaminated with toner or paper dust.
Simple solution, clean the pickup roller, the best thing for this is WD40, put a very small amount on a clean cloth and wipe the roller underneath the printer. Use a clean dry piece of cloth to wipe off any residue.
More complicated solution, remove the roller and reposition, you will need two small flat-bladed screwdrivers to pry apart the retaining clips, remove the roller, a tight squeeze beneath the laser housing, reposition and clean as above then refit the roller. You should find that the paper is picked up cleanly once again.
I hope this helps,
Jan 18, 2008 | Samsung CLP 300 Laser Printer
Brother Intellifax 1800C-jamming issue
First, check your rollers for a small piece that may be stuck between the rollers causing the jam.
Second, make sure there is not to many sheets in your tray.
Third, make sure that you have not pushed the paper down to far in the tray this uaually makes the machine grab more than one sheet.
good luck
Jan 10, 2008 | Brother IntelliFAX 1800C All-In-One...
Hp paper feeder wont thu printer
paper feed rollers wont feed paper through and also paper tray is empty prompt comes up when there is paper in the tray tried small amounts of paper and still says tray is empty
Dec 27, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Dell Laser MPF 1600n WON'T PRINT
Two causes:
1. Worn out roller
<or>
2. Spring-loaded tray not engaging when placed into printer
1. The roller will try to "grab" the paper when the job starts. If it becomes too worn, it will slip and not grab anything. One fix is to apply a small amount of moisture to the u-shaped rubber roller.
Other option is to wrap a rubber band around it if you can.
2. Check to see if tray spring works properly. There is a small white knob on left side of tray. Push paper in tray down all the way until it clicks. Engage knob on side and paper should spring upwards. If this does not happen, the roller will not be able to engage the paper and it will simply click as it tries in vain.
Dec 07, 2007 | Dell 1600n All-In-One Laser Printer
24 people viewed this question
k24674
jasbo
jasbo
