Question about Bernina Sewing Machines
Cant get benina 830 to turn on
My bernina 830 record electronic sewing machine is plugged in the light comes on but the machine needle will not move when pressing on the foot pedal
    Top Expert:
  • Bernina Master
  • 47,776 Answers
Take it in for a service
could be foot pedal problem or motor problem
Posted on Dec 16, 2016
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
My Bernina 830 sewing machine makes initial starting noises but does not come on, anything I can check? I've already unplugged and plugged it back in.
Assuming it is an 830 Record (old mechanical, not the new computerized model). If it sounds like the motor is straining but the machine's mechanics are not working, then the machine has most likely seized from old, dried up oil.
This is the method I've used on multiple seized machines and works:
This is the oil port diagram for the 830 Record.
Jan 02, 2017 | Sewing Machines
I am looking for a bernina 930 service manual. I dropped the feed dogs and they will not come back up.
Most likely they have seized due to lack of regular oiling. I have used the following method on several older seized Berninas with great success. Just be sure to NOT get any oil near the 930 basting stitch mechanism (about the middle of the needle bar) or it will most likely lock the machine.
This is a diagram for the Bernina 830 Record, but it will give you a good idea of what & where to look for oil ports.
I've never used this source (use at your risk):
Bernina record 930 electronic service manual
Nov 25, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
My old Bernina 830 has ceased after not being used for 8 years what can I do?
I have resurrected several older Berninas with lots of patience and elbow grease. Here's how:
Bernina 830 Record oiling points:
Dec 29, 2015 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
My Bernina 830 sewing machine will not sew any of the decorative stitches.
Is this the vintage 830 record, or the new electronic model?
If it's the Record, flip the top open, and oil all metal-to-metal. Run for a full minute, oil again, and run another minute. It should start to work once the oil has been worked in.
Mar 05, 2015 | Bernina Sewing Machines
Sewing Machines Logo
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
